Question about Dishwashers
Salt compartment not draining
When I switch on my Beko DWD5410W dishwasher, it starts making immediate noise just like it's set on a wash program. However, it is not on a wash program. If I do select a program it makes no difference. It will just hum and throb forever.
Additionally, when I unscrew the cap over the salt compartment, water floods upwards and out.
Twice I have taken the dishwasher outside and turned it upside down, and both times it has worked thereafter, but only for a couple of days. Tonight I used an ultra-absorbent cloth to soak up all of the water in the salt compartment (rather than taking it outside again), however this has made no difference.
I have tried holding down the Start button long enough to cancel any active program, but this is not relevant as no program is active.
Can anybody help me?
  • Craig Cullen Aug 03, 2009
    In case anyone else ever has this problem, I'll answer it myself.
    Got an engineer out today to have a look. Our problem is a leak in the main motor seal. The salt compartment issue is probably a red herring and perfectly normal.
    The leak leads to drips landing in the drip tray underneath the dishwasher. That drip tray has a float, and when that float detects that the drip tray is full, it stops the dishwasher from working. This manifests itself by the dishwasher switching on and making noise but being unable to take a program or do anything other than make the noise.
    Thus, draining the drip tray will drop the float and make the dishwasher work again.
    Sadly, however, the motor seal is not replaceable without a complete new motor, and a new motor will cost about 75% of the purchase price of a brand new one.
    Them's the breaks.
    Hope this helps somebody else in future.
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 1462 Answers
SOURCE: salt for DDW1805 Danby
yes it is - salt is used to regenerate the water softener in the dishwasher
Posted on Jul 12, 2008
SOURCE: Whirlpool ADP 9520
press the start button (which is flashing) for a few seconds and it should start again?
Posted on Aug 20, 2008
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
Just go here and download your DWD5410W manual. Just to remind you you mast have Adobe reader to open it. Than you can print it if you want.
DWD5410W manual in .pdf format
Jun 04, 2011 | Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Mar 14, 2011 | Dishwashers
Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
May 09, 2010 | Dishwashers
My Milee dishwasher indicated that I should add salt to the salt reservoire. I did this and then started to run a quick wash. However, the machine started to make a strange grinding noise. I turned it...
If noise occurs within first minute of starting program, then the is most likely something in the drain pump. Remove filter, On left of sump you will see a non return valve with a metal clip keeping it in place push clip ti centre of sump. remove non return valve and rotate impeller. Start a program, after 60 sec stop program, (debris will have been thrown out of pump.) re-assemble and test. More in depth instructions are in user manual under problem solving
Apr 03, 2010 | Miele Dishwashers
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Push start button fills with 2in of water then does nothing
hi there........this fault is usually associated with a faulty flow meter....situated on the lower left hand side of the apliance and is only accessible on removal of the left hand cabinet panel
regards Sir Galahad
Apr 15, 2009 | Beko 24 in. D3421F Free-standing...
I have a 2yr old Beko D2731FW dishwasher that has recently started to not wash things properly and leaving a gritty residue on everything. I run a dishwasher cleaner through it on a monthly basis and the...
Hello Senseless,
Although I am not familiar with your specific brand and model dishwasher, I can offer you some advice on how to clean things up.. First off, remove all dishes from the cleaning compartment racks.. then your dishwasher may or may not have a drain screen or filter near where the water exits that compartment to be pumped out.. rclean that filter thoroughly. Then run the dishwasher on its hottest cycle setting ( without dishes inside ) and after about 5-10 minutes..pause it and add in a cup or two of white vinegar then restart it.. Let the dishwasher complete the cycle and try washing dishes with it. That technique should cleanse deposits of components inside the dishwasher and everything should work as designed. I am assuming that you aren't getting any backflow from the drain system back into the wash area from the drain hose/pump and associated connections. If you are, you may need to give that plumbing a thorough cleaning too. Let me know if after you've tried this, you were successful.. If not, then I can provide you with a few other things that may help..
Dec 04, 2008 | Dishwashers
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
