Question about Nokia 6100
Unable to connect via Data Cable with Computer (OS = Windows XP)...Error Displayed Unspecified USB DeviceTried to Install Nokia 6100 Cable (Modem) Driver Downloaded from Authorised Nokia Website But Failed... No Com Port Displayed
Re: Unable to connect via Data Cable with Computer (OS =...
Try to update the BIOS on your comp....and check....
Posted on Mar 12, 2009
  • 4,102 Answers
This is a problem with your computer did you get a disk with the lead you need to tell the computer what you are plugging into your comp i had the same problem when i plugged a memory stick into my usb port so i had to search the net for the software and even when i had the software only one of the usb ports would let me use the device the other port was telling me to remove the devide hope this is some help dont know where you can get the software for your device my comp gave me the options of letting windows search the net for compatable software and it found it for me and now i have no probs
Posted on Nov 23, 2007
0 characters
3 Points
Whenever i m connecting the cell phone(nokia 3110 c) with the laptop via USB cable the laptop shows me message that DRIVER missing. i want to use the data cable for net connection. pls let me konow from...
Good Day,
For your driver need, you may just install Nokia PC Suite, where it installs the driver and other necessary software, including the software needed for you to use the phone as an internet device.
just go to that link, install the software, and you are set. Please do not connect the USB data cable to the PC yet, until the software installation is finished. After all has been installed just plug the USB data cable in the PC and the phone, and follow the instructions on-screen.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia 3110 Cellular Phone
How to copy contacts from nokiaE63 to pc via nokia pc suite?
Download the nokia PC suite from the nokia website.
Connect your mobile using the USB data cable come along with nokia box pack.
After connecting the phone open the windows explorer.
Go to Nokia browser which will be displayed in windows explorer.
After opening the nokia browser contacts and message folder will be dispalyed.
When you open the contact folder you will be prompt for the message update the contacts.
Then update the contacts and after that you are able to copy the contacts from phone to your
Apr 03, 2011 | Nokia E63 Cell Phone
I can not connet the internet via samsung gt s 3653 mobile usb cable. When i canect the usb cable with my computer ask mobile usb modem 1.0 . Also can not download mobile usb modem 1.0 .
Before connect you Corby to PC you must install Samsung PC Studio in your PC. You can download PC Studio and User Manual from here :
Click at software, then click at download icon.
After finishing download, install the driver. If the installation complete, you can connect your phone via USB cable data.
Hope this help and if this helpful RATE please.
Feb 03, 2011 | Cell Phones
Motorola phone tools does not find my motorola v235
Did you download and install the Motorola USB Data / Modem drivers? If not, you will need to.
Motorola Mobile Phone USB Drivers (for Windows®) This USB Driver is used for connecting your Motorola Mobile Phone to a Windows® computer via a USB cable in order to charge your phone or to access the data on your phone.
Supported Handsets This USB Driver supports most Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile® and Motorola i-mode Handsets.
System Requirements
  • A 32-bit or 64-bit version of Windows 2000®, Windows XP®, Windows Vista® or Windows 7® Operating system.
  • You must have Administrator permission to install this driver.
  • Please reboot the system after installing the USB Driver.
  • Installation of Motorola Phone Tools may affect the performance of this driver. Please re-install the USB Driver after the installation of Motorola Phone Tools.
* MotoConnect is a PC application that keeps your Motorola device drivers up-to-date. Additionally, on supported phones, MotoConnect can launch the owner support page for your phone giving you easy access to user guides, FAQs, tutorials, videos and more.
Go to this website and sign up to be a member. You can then download the USB drivers there.
Feb 15, 2010 | Motorola Mobility V235 Cellular Phone
LG tu550 and Windows XP professional
If you want to use a cable connection, go into the phone menu and select the following:
Menu > Settings > Connectivity > USB Connection Mode > Mass Storage
After this, plug the phone in via the USB cable.
The computer will prompt to install the modem driver which you can cancel.
Then the computer should detect the memory card as a USB drive and you can copy and paste what you need.
Hope this helps
Mar 05, 2009 | Cell Phones
Unable to connet mobile phone to PC
because you have no pc suite try to install software like pc suite or connect it via blutooth,,,
Feb 04, 2009 | Nokia 2626 Mobile Phone
How to install modem of Nokia 6080 using CA-42 data cable'?
plug the data cable with your computer and restart your computer. the operating system will automatically detect and will configure the necessary setting. if that did not happen then you have not bought the right cable. check the phones manual for the correct specification
Oct 05, 2008 | Nokia 6080 Cellular Phone
Nokia 6101 driver
     to connect via cable..u frst need to install the drivers of cable & than u need to go to control panel>phone & modem options> in that click on modems tab> in that check for ur hndset modem. If u dnt get 6101 modem than click on add new than select dont detect my modem i will select it from the that either u will get nokia or standard modem..if ur geting nokia than select 6101 model & press next..if ur geting standard modem than select 9600bps modem..after select either of them select the port in which u want to install the modem should be more than 2..after that u can connect
Oct 22, 2007 | Nokia 6610i Cellular Phone
Hey guyz the above information is absolutely right....i downloaded MOBIMB software...i have a DKU-5 showed my mobile NOKIA 2626 in the list and guess what...i was even able to play the nokia ringtone on my pc....
Jul 09, 2007 | Nokia 2600
Nokia 6100 Logo
102 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
