Question about Radio Communications
Can't find plans for German bilt typ2330 Radio fm - sw - lw -CB
  • 150 Answers
SOURCE: cb radio
Not without some serious board modification.
Posted on Sep 15, 2007
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Posted on Mar 20, 2008
  • 77947 Answers
SOURCE: Hi i have a ford focus 1.6
This problem is caused by most commonly by a poor Antenna ground, and 2nd the radio chassis ground.
Posted on Nov 24, 2008
  • 1861 Answers
SOURCE: 2007 Toyota Sequoia Dashboard Access to Radio console FM Antenna
Pull off the 3 knobs for the heat controls. You will see a screw under the center knob. Remove it. Look to see if there are any screws near the vent grilles, remove them, if they are there. The whole center fascia then pulls out towards you. Remove the 4 bolts, and the radio is out. Easy.
Posted on Feb 07, 2009
How do I set the. Time
With the radio off, press and hold the ENTER (time set) Key DOWN. On the right side, there are 4 buttons with arrows on them. The inside ones set the timezone that you are in, the outside two will set the time. I just checked this on my ICF-SW100 and it works for me.
Mar 04, 2015 | Sony Icf-sw100 World Shortwave Receiver...
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
This galaxy dx44v is a new thing to me.. what is the diff between am and fm?? i guess i had alsways thought one was for hamms and the other was a cb channel.. and i never had a radio with all them side...
Normal 1-40 uses AM.. there are many modulation forms. AM FM SSB CW and many other digital modes. its the same frequency just different way of voice modulation styles.
Jan 30, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
I have had the Grundig G400 AM FM LW MW SW FM STEREO PLL SYNTHESIZED DUAL CONVERSION I have no Manual and can,t install my batteries correctly I would like to purchase a Manual if it is possible to do so...
This link will take you to the Grundig/Eton site where you can download and print the complete manual for your radio:
Bill B.
San Antonio
Apr 24, 2009 | Grundig G4000A FM/AM Radio
Sharp wf 940 portable cassette / radio player
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
Cb radio
Sep 15, 2007 | Radio Communications
Radio Communications Logo
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
