Question about Canon Office Equipment & Supplies
My canon ir 3320i copier toner is leaking from drum unit fix it
I can not copy a4 and a3 copies but legal paper its ok because the toner getting leak corner of the a4 and a3 paper
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Can u plz Check Cleaning Blade and Mylar sheet for cut,
Check Charge Roller if gone bad.
if both seems to be ok, then change Drum Unit .
Posted on Aug 13, 2017
jaylex
  • 417 Answers
SOURCE: A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Posted on Feb 17, 2008
  • 100 Answers
SOURCE: A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Posted on Aug 04, 2008
obzy
  • 31 Answers
SOURCE: size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Posted on Apr 10, 2009
SOURCE: My old Canon NP1215 Copier: -First copy is
change drum unit still making lines
Posted on Mar 03, 2010
canontech
  • 1219 Answers
SOURCE: IR4570 paper jams at fixing unit whenever i try to
first clean all rollers espc. below the drum unit two rollers on axis, if the paper comes out bent in the roll open fresh pack of paper because of moisture, when you open the right door above fixing unit you will see one more small door that is loosen, on these inner door you will se long plastic flapper ( ussually black plastic with small picker fingers ) that is connected to solenoid, these flapper has on both sides some kind of sponge sticker on left and right space where it touch the inner door - REMOVE THEM.
Hope that helps!
For service manual write me on emma.servis@gmail.com
Posted on Sep 09, 2010
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
A toner catridge leaked in my Canon PC921. I cleaned it up and installed a new cartridge, but now my copies are dark on one side, light on the other.
on analogue copiers, if You have dark copies, that means that You need to clean optics ( mirrors and lenses - maybe some toner get to them ) or check/clean/replace the fixing film!
Regarding poor copy, clean/vacume/change the transfer roller ( beneath the drum unit - on paper path from drawer/bypass, before fixing unit ).
Hope that helps!
Apr 11, 2011 | Canon PC-921 Black and White Copier
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Ir 2200 a3 paper at the end is
Try to flip the A3 paper (in your paper drower), it may be if it isnt used so often it can be moisty, so when it pass the fixing roller, he bacames undulate.
Or if A4 is ok, that means that sorter does not work OK, because the A3 is longer and it pass longer way and more rollers.
Nov 11, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Sep 01, 2008 | Canon NP 7130 Black and White Copier
46 people viewed this question
old marine
old marine
