Question about Car Audio & Video
I have furia 2011. I dont know how to connect ignition barrel. Thereis four wires : yellow, grey, green and black.
  • 351 Answers
SOURCE: hoover 710 top load washer
They sound
Posted on Mar 02, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 173 Answers
SOURCE: i need the radio wiring diagram for a 1992 cadillac eldorado
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
Posted on Mar 25, 2010
ZJLimited
  • 17970 Answers
SOURCE: need to know how to hard wire ignition module
Ford has substantially altered their 1978-86 electronic ignition test procedure. Due to the sensitive nature of the system and the complexity of the test procedures, it is recommended that you refer to your dealer if you suspect a problem in your 1978-86 electronic ignition system. The system can, of course, be tested by substituting known good components (module, stator, etc.)
This system, which at first appears to be extremely complicated, is actually quite simple to diagnose and repair. Diagnosis does, however, require the use of a voltmeter and an ohmmeter. You will also need several jumper wires with both blade ends and alligator clips.
The symptoms of a defective component within the solid state system are exactly the same as those you would encounter in a conventional system. Some of these symptoms are:
- Hard or no starting - Rough idle - Poor fuel economy - Engine misses while under load or while accelerating
If you suspect a problem in your ignition system, first perform a spark intensity test to pinpoint the problem. Using insulated pliers, hold the end of one of the spark plug leads about 1 / 2 inch; (12.7mm) away from the engine block or other good ground, and crank the engine. If you have a nice, fat spark, then your problem is not in the ignition system. If you have no spark or a very weak spark, then proceed to the following tests.
Tell if you are talking about this ignition system...
Hope this help.
Posted on May 11, 2010
  • 59 Answers
SOURCE: I just bought a Panasonic CQ-C1301U deck, and want
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Posted on Nov 11, 2010
I have a sony cdx-s2010c stereo im not sure how the 11 wires are supposed to connect to my care wires I cannot find any free manuals on this
if you tell me what car you have i can provide you with the an wiring guide for your specific car.
Left front: White/ White - Black
Left rear: Green/ Green - Black
Right front: Grey/ Grey - Black
Right rear: Purple/ Purple - Black
Constant power (battery): Yellow
Ignition power: Red
Earth: Black
Amplifier Trip: Blue/ Blue - white
Antenna Trip: Blue
I hope this has helped, if you need more information please contact me.
oh and dont forget to rate my solution.
cheers
Jan 12, 2011 | Toshiba Sony CDXS2010
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
I dont know how to hook it up
The gray are for the right front speakers, there should be 2 white wires for the left front speakers, the purples are for the rear right speakers and the greens are for the rear speakers. The blue is for a power antenna or a remote amp, the red goes to battery ignition, black to ground and yellow to constant battery power, for the stereo memory.
May 15, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
2 grey 2 green and 2 purles are speaker outputs. one of each color should have a black line. thats usually the speaker negative. blue is remote power out to connect to remote power to amp. red is 12 volt power(+). black is power ground (-) yellow is switched power from fuse block.
Mar 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
I have taken out my standerd sterero in ford fiesta 1996 and cut off the block dont know what wires are what and now clock dont work ant think i have blown the stereo can any one tell me what wires are...
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
Apr 13, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
