Question about Exercise & Fitness
Hi. I have a healthstream genesis treadmill GE3200T model and I have just set it up after it not being used for quite a while and when I turn it on it is beeping and it has Er - 7 on the screen?
SOURCE: Genki Treadmill error 'ER'. Need tech details or contact.
I have a Genki treadmill that i cannot get fixed, so if you would like the safety key please contact me lisagidleyking@hotmail.com and i will send it to you.
Posted on Jun 22, 2010
  • 218 Answers
SOURCE: how can fix my healthstream LS720T treadmill?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
  • 33 Answers
SOURCE: When I start my Healthstream
Issue might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
ercupa190
  • 12223 Answers
SOURCE: Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Posted on Jun 13, 2012
redy2rumbl
  • 56 Answers
SOURCE: I keep getting a beep when I turn the computer on....black screen...and nothing
If the computer is out of warranty, you dont have anything to loose. Have the northbridge and video chips re-flowed. You can do this using a heat gun, but
you have to be very careful not to destroy your board. This is a similar problem that XBOX360 owners were having with the red ring of death. These boards run very hot and over time and many cycles of heating up and cooling off the
chipsets separate from the mainboard and your computer becomes useless.
I dont have a board in front right now but if my memory serves me right place
the board in front of you so the hard drive connections are on the left side of
the board and the CPU socket is facing up. the 2 chips you want to work on
are just to the right of the CPU socket and just above the CPU socket. Be
sure to remove the CPU before you put any heat on these chips. Use circular
motions with the heat gun on HIGH. You may need to get some flux to put around each chip before doing this, but in my case I didnt have to. There was plenty there already. Computer worked for about 6-7 months after my fix and then needed the same repair again. If you want to see this done there are a lot of videos on the XBOX360 being done on youtube so to kinda give you an idea of how to do it. Might not be worth the trouble and you might be better off parting out the machine and just buy another one. Its all up to you, I hope this helps
I just bought a new system
Posted on Aug 24, 2012
How to fix e7 on healthstream genesis treadmill
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 12, 2016 | Exercise & Fitness
I have just bought a EVO Healthstream treadmill ev525t to help my cancer child to keep moving. I got it secondhand and it screams E6 and mat wont even move. I so upset i dont know where to buy parts
This product is very unreliable and if you purchased it 2nd hand you know why the owner wanted it gone. The base of the machine also breaks after regular use.
Unfortunately they are also expensive to repair and I would not be throwing any money at it but try to sell it off as a repairable item.
An inexpensive exercise bike is probably a better choice than a treadmill which generally are quite expensive for a quality product.
Apr 24, 2016 | Exercise & Fitness
Want to download a manual for the healthstream GS1180T
Your model doesn't seem to be listed on the manufacturer's website. Contact them directly for additional support.
http://www.healthstream.com.tw/index.php?act=contact
Feb 24, 2015 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream gold series model no GS1160T is coming up with E1error code. What does this mean? Treadmill will run for a few seconds then switch off
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Adjust the Speed sensor according . Test for open or faulty458ecb9c-392b-4a17-8105-4b76ec52d9b4.gif192107ed-2567-439d-9172-83a32cb4381b.gif
May 31, 2013 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
Jul 30, 2010 | Exercise & Fitness
Healthstream genesis exercise bike
This depends on the model you have. There are lots of genesis bikes have manual resistance knobs on the main post, right in front of the seat. If it doesn't have a knob here, then it might be electronically operated in which case there might be a problem if it isn't adjusting with the program.
Sep 28, 2008 | Sport & Outdoor - Others
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
