Question about Insignia Computers & Internet
My Insignia tablet has been having thermal events. The last one caused it to shut down. What can I do to stop this behavior?
It has been on for 4 to 5 hours.
  • Insignia Master
  • 10,045 Answers
Let the boys at Best Buy trouble shoot it to find the offending part.
Posted on Aug 13, 2017
CrazyLarry
  • 173 Answers
SOURCE: tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Posted on Jan 26, 2008
Benimur
  • 6966 Answers
SOURCE: OVER HEATING
Two possibilities:
  • the CPU is really overheating; and/or
  • the motherboard is falsely sensing high temp.
Corrective measure for an overheating CPU would be:
  • clean, re-lubricate or replace the fan;
  • clean or refit the heatsink. If it is overclocked, you may need a better heatsink.
If the CPU is not really heating up abd the motherboard is sensing erroneous temp readings, then the problem may be with:
  • BIOS version, try to flash and update the BIOS; and/or
  • check the temp probe underneath the CPU, it may need cleaning or slightly bending away from contact.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
  • 4 Answers
SOURCE: gateway e-4100 thermal event
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
Posted on Nov 25, 2008
  • 52 Answers
SOURCE: Thermal Event
This is likely one of the following:
1) the thermal paste under the fan is dried up and needs to be redone
2) The case needs to be blown out of accumulated dust
3) the motherboard has an electrical problem (old capacitors failing etc.)
It could be all 3 issues.
If you are somewhat skilled the first 2 are easy.
The last one can be fixed in many cases
Posted on Aug 06, 2009
Testimonial: "Thank you, I will give the ternal paste a try!"
CoquiBiz
  • 103 Answers
SOURCE: When I boot the machine it gives me a thermal
Theres many types of sockets for motherboards. If PC clone, search for the book manual for pinpoint wath socket it it or it is a IBM or DELL or HP, the same except the latter is little more tricky when detaching the heatsink. Once figured out, disconect the power, touch the fuselage of the PC to discharge from ESD. Of course, buy a heatsink compound and you can clean the cpu and bottonm of the heatsink with paper towel and Isopropyl Alcohol and apply new compound. Not too much, the nessesary only. I'd like to apply in a whirpool like on the CPU. And the heatcopound color grey is the best.
Posted on Aug 21, 2009
What is wrong when tablet says thermal critical event occurred and tablet shuts down?
This means the tablet got to hot and presented a fire hazard. Only a few things cause the overheat, first is a failing battery and the last running data heavy programs like complex video games. Those types of programs draw a lot of amps and can overheat the tablet.
Mar 21, 2017 | Tablets & eReaders
How can I connect my insignia tablet to a keyboard?
Hi Roberta
Perhaps an Incompatibility.
Time to Rely on the Warranty... It does have a warranty... right
If Not....
There is a service agent or even the people you bought it from!
When buying electronic products it's times like these that you need good customer service.
I try to think of this just before buying my product.... even if it costs a bit more.
apple costs more but it's dependable
Good Luck
Mar 03, 2015 | Insignia - Flex 8 inch Tablet with 8GB...
Acer iconi b1 thermal warning
why does my acer iconia keep saying Thermal warning and shutting down when I have only just switched it on?
Nov 26, 2013 | Acer Iconia B1 7-Inch Tablet Black Dual...
Insignia lcd tv shuts off after 2-3 seconds
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Dec 14, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
In dg41wv server 2003 is not loading
problems in Windows Server 2003
To start the computer by using Last Known Good Configuration, follow these steps:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press Enter.
Collapse this imageExpand this image
Note NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If you are running other operating systems on the computer, click Microsoft Windows Server 2003 on the list, and then press Enter.
Notes
By selecting Last Known Good Configuration, you can recover from problems such as a newly added driver that may be incorrect for your hardware.
This feature does not solve problems caused by corrupted or missing drivers or files.
When you select Last Known Good Configuration, only the information in the following registry key is restored:
HKLM\System\CurrentControlSet
Any changes that you have made in other registry keys remain.
If you can start your computer by using the Last Known Good Configuration feature, the last change that you made to the computer (for example, the installation of a driver) may be the cause of the incorrect startup behavior.
if this fails to fix the problem try to repair in safe mode
How to start the computer in safe mode
When you start the computer in safe mode, Windows loads only the drivers and computer services that you need.
You can use safe mode when you have to identify and resolve problems that are caused by faulty drivers, programs, or services that start automatically.
If the computer starts successfully in safe mode but it does not start in normal mode, the computer may have a conflict with the hardware settings or the resources. There may be incompatibilities with programs, services, or drivers, or there may be registry damage. In safe mode, you can disable or remove a program, service, or device driver that may prevent the computer from starting correctly.
To troubleshoot startup problems in safe mode, follow these steps:
When you see the message Please select the operating system to start, press F8.
On the Windows Advanced Option Menu, use the arrow keys to select Safe Mode, and then press Enter.
Note Num Lock must be off before the arrow keys on the numeric keypad will function.
Do one of the following:
If the computer does not start in safe mode, try starting the computer by using the Recovery Console. If you still cannot start the computer, look for possible hardware problems, such as defective devices, installation problems, cabling problems, or connector problems. Remove any hardware that was added recently, and then restart the computer to see if the problem is resolved.
If the computer starts in safe mode, go to the next section to continue to troubleshoot the startup issue.
Use Event Viewer to identify the cause of the startup problem
View the event logs in Event Viewer for information that can help you identify and diagnose the cause of the startup problem.
To view events that are recorded in the event logs, follow these steps
Click Start, point to Administrative Tools, and then click Event Viewer.
Start the Event Viewer snap-in in Microsoft Management Console (MMC).
In the console tree, expand Event Viewer, and then click the log that you want to view. For example, click System log or Application log.
In the details pane, double-click the event that you want to view.
To copy the details of the event, click Copy, open a new document in the program in which you want to paste the event (for example, Microsoft Word), and then click Paste on the Edit menu.
To view the description of the previous event or the next event, press the UP ARROW key or the DOWN ARROW key.
Use this tool to help identify possible problem devices and device conflicts.
To do this, follow these steps.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
you might be able work your way through the problem
hope this helps
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
I can't shut down my PC,It restarts again!
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Thermal Event
Aug 06, 2009 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
