Question about Tablets & eReaders
I have white circle beside the battery status bar with a line in the middle and I think it's causing my tablet to not charge.
3 Suggested Answers
  • 45 Answers
SOURCE: My samsung galaxy tablet 10 1 has been off for
Plug it in to a USB on your pc or laptop. Let it charge for 1 hour then try holding in the power button while it is still attached to the computer.
for some reason samsung tablets like the charge from a computer or laptop better than mains power.
Posted on Mar 23, 2014
20sms02
  • 7 Answers
SOURCE: Trio stealth tablet theres a line down the middle
You probably need a new display... I had the same and that fixed it...
Posted on Jan 21, 2015
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
How to fix a imito tablet that wont turn on?
When you are sure the battery is fully charged I don't think there is much you can do.
Lots of things, like a bad charger, a bad cable, bad connectors and a bad battery, can be the cause the tablet does not have enough power. But when there is enough power, the on / off switch cam be defect, or any electronic part in the tablet could be. Without the tablet i my hands and measurement tools to verify everything it will be impossible to tell what is wrong. Take it to a repair centre, but before you leave it, ask what they charge for the diagnose. Not sure you can swap the battery and how difficult it would be to get one?
Perhaps that is the problem, but don't take my word for it.
Sep 06, 2014 | Android Imito Im7 2.1 7" White Tablet Wifi...
What can my problem be
such symptoms usually occur only when the battery is weak and need to be replaced.
- other reasons can be:
1) a faulty charger
2) a bad cable
-change to another electric outlet
-let the iPad be connected with the charging cable while using
-to have a better control about battery status activate battery percentage display to ON in the settings
How to see the battery percentage in my iPhone's status bar.:
- The iPhone ships with this feature disabled by default, and Apple hides the option away within the device's general settings. So, here's how to enable it!
Open up the Settings app on your iPhone and tap on the 'General' tab. You'll see an option "usage"
then you'll see an option for 'Battery Percentage' - simply turn this on and your iPhone will now display your remaining percentage next to the battery indicator in the status bar.
problem-z4ipswfycprf0ccft4hwg0fn-3-0.jpg How To Display The Battery Percentage On Your iPhone iOS Tips Cult of Mac
problem-z4ipswfycprf0ccft4hwg0fn-3-2.jpg Enable Battery Percentage Meter On iPhone iPad or iPod Touch
Aug 31, 2014 | Apple iPad 32 GB WiFi Tablet PC
Sm-T210R tablet will not turn on or charge
Plug in your tablet, hold the power button while also hold downing the home button (white, black or silver button on front of tablet beside the return key) until the battery icon shows on the tablet. If this doesn't work and you are still under warranty send it back to Samsung. If no longer under warranty you will need to remove the entire back of the Tab and disconnect the battery from the motherboard. I do not give advice on doing this and you will have to look elsewhere for that procedure. I hope the simple fix works.
Aug 28, 2014 | Samsung Tab Tablets & eReaders
My samsung galaxy tablet 10 1 has been off for months i lost my charger Found one on amazon Plugged it in last night and the back light came on with the battery icon in the middle with a thinking timer in...
Mar 23, 2014 | Tablets & eReaders
Kocaso tablet
try to get a new battery I think it means the battery is too weak
Feb 01, 2013 | Belkin N Tablets & eReaders
How do I know when my Samsung Galaxy Tablet is charged? How long should it stay plugged in?
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Hope this helps, Alistair
Feb 23, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
63 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
