Question about Blu Cell Phones
Blu studio 5.5 c d690 no audio like no ring tones no notifications sounds and no viberations and callers cant hear me unless i use head phones w/ mic. i can hear callers just fine
  • 384 Answers
  • turn your volume up on your phone at top swipe down or hit side button volume levels will pop up raise volume !! on all fields try restarting phone run anti malware spyware program a must !!
We Are Here To Help !!
Donald Deane MCSE,ASE,CPO
Posted on Aug 13, 2017
Testimonial: "i did do my research i tried all at even doing hard reset soft reset ect. see this all came after the phone got stuck on the white BLU logo aminated start just kept flashing on and off playing the start sound as well. so i just put the phone away and left it for afew months now i need it did more researching came to the conculsion i needed to flash it with the proper rom or firmware i did the firmware with sp flash tool. phone came back on but like i said has no audio no viberate what so ever not even touching the screen can i get a touch tone or viberate when i touch screen got me total stumped and stressed i bought this phone brand new off ebay only used like 4 mths. before it got got stuck on the boot load. been in the draw for like the last year"
  • Donald Pera Deane
    Donald Pera Deane Aug 13, 2017
    Ok probably the rom version you flashed it with was corrupt try to reflash make sure your computer you use is free of malware,viruses And spyware and your system is running at optimum performance levels, then try to reflash with the correct flash utility and a good rom Good luck !!
  • Donald Pera Deane
    And Don't Forget you can always do a factory reset!!
pingping
  • 111 Answers
SOURCE: Phone rings but when answered the caller can not be heard.
Your ear speaker is bad. You may need to replace it.. This one made by HTC. You can check on Ebay for replacement part. Other issue could be is the hardware part of the ear speaker may be broken or defected will cause loosing contact with the main circuit or you can say it is short. Only solution is open the phone and check for that area to see for any defective.
Posted on Apr 23, 2007
SOURCE: can hear callers they cant hear me on skype although mic unmuted
When was the last time it worked?
Posted on Jan 07, 2008
  • 15 Answers
SOURCE: The caller can hear me but i cant hear the caller.
please check for the speaker volume in ur phone and if still continues speaker has to be replaced
Posted on May 14, 2009
  • 6 Answers
SOURCE: when i try to dial out there i hear no ringing
One of 2 things.. either your main speaker is shot, or your phone needs programming. The new LG's often need further programming to be completed at your local service branch. Takes 5 minutes max.
Posted on Jun 11, 2009
SOURCE: will not ring for incoming call only viberates
You should try to put it on only ring cause some phones have issues simular to yours.
Posted on Jan 31, 2010
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
How do I get the ring tone on my phone to work?
These smartphones controls all sounds with the volume rocker, the only problem is that it controls only what is currently being use. Just go to any ringtone and tap it in order to play it. While it's playing, use the volume rocker up to raise the sound.
Dec 13, 2014 | Samsung Cell Phones
How do I add my own message tone to phone , I have had the tone sent to me via blue tooth but cant work out how to select and add it as message tone . can only find ring tone , alarm tone and caller tone.
Step1: Click on "applications", then select "My files" Create a folder in the root menu and call it "media"
2. Click on media then create another folder and call it "audio"
3. Click on audio to enter then create the final folder and call it "notifiations"
4. When you have done this transfer your message tones to notification folders
5. Go to message,setting,select ring tones and you will see your files
Hope it helps.
Jun 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
How do i change my message alert on my sony x10
1)Connect your phone to your computer.
2)Mount your SD Card.
3)If you have PC Companion, goto file manager... if not goto My Computer and open your SD card.
4)Create the following folders "SD Root folder":\media\audio\notifications
4a)ADD YOUR RING TONE TO 'NOTIFICATIONS'
5)Unmount SD Card
6)Open Messenger
7)Open Settings
8)Open 'Select ring tone' (You better have notifications already selected...if not...this little list is too much for you to handle.)
9)Select Ring tone, it is labeled however the file was named.
Oct 21, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Will not ring for incoming call only viberates
Jan 31, 2010 | Motorola Mobility Adventure v750 Cell...
Nokia E61 no sound
plz master re setting if prob not solve then u can change u phone sound ic
Jul 20, 2009 | Nokia E61i Cellular Phone
Cant hear the caller
It sounds like the speaker at the top of your phone is messed up. This is a common problem after drops.
Apr 20, 2008 | Sony Ericsson W550i Cellular Phone
Cell Phones Logo
87 people viewed this question
Top Blu Cell Phones Experts
Hjalmer Lamminen
Hjalmer Lamminen
Dustin
Dustin
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
