Question about Masonry Tools
I broke the fence bracket on my Hafco 150 mm jointer and I'm looking for a replacement? model no P-150. Year 1985
4 Suggested Answers
  • 10865 Answers
SOURCE: I AM LOOKING FOR A MANUAL FOR A ROCKWELL JOINTER 37-600
go to this site and call rockwell on the number provided.
http://rockwelltools.com/service_parts.htm
Posted on May 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: need a replacement motor for 1972 craftsman jointer
went to Sears site and no luck most parts are discontinued. So maybe try Grainger with the information from the data plate on the motor for a replacement or check in yellow pages for a local dealer of electric motors. I don't really think that there should be anything special as long as the output shaft and mounting are the same. Good luck sorry I don't have better info for you.
Posted on Sep 24, 2009
SOURCE: I have aphillips tv, model number 42pfl7603d/10. The stand which it sits on at base of tv has broke, I'm looking to find where I get a replacement one. My walls will not support brackets for it
The only place I found that has one is in the UK
http://www.ebay.com/itm/TABLETOP-STAND-FOR-PHILIPS-42PFL7603D-37PFL7603D-37PFL5603D-42PFL5603-LCD-TV-/360506039050?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item53efd59b0a
Posted on Dec 06, 2012
In feed table is not level from front of table to fence
Fill feed table with water and measure water level at all corners and adjust until all corners have the same water depth. Then then drain and fill with feed. The fence should be near the feed table.
Aug 12, 2013 | Delta X5 Dj20 8" Precision Jointer
Cannot keep fence square to bed it keeps moving. Jet JJ8CS what could be causing this?
The clamp on the near end can be tight but the one on the far end tends to loosen unless you really tighten it and check frequently
Mar 06, 2013 | Jet 708458K JJ-8CS 8-Inch 2 Horsepower...
How much does it cost to start fencing?
Beginner's dry fencing setup is around $150 including cotton jacket, gloves, dry weapon and a mask. If you willing to go pro the competitive setup cost around 800$ and includes 800N jacket, 1600N mask, at least 2 electric weapons, body cord, socks, glove, shoes, lame (sabre only), sensor (sabre only). The cost of joining a club vary but usually 100$ per year, some club even provide fencing kits for beginners.
Jul 29, 2012 | Sport & Outdoor - Others
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
I have Craftsman 6 1/4 Professional Series Jointer Model #150-217060 and I would like to know where I can go on line to download the owners manual for this power tool
I don't know whether you ever got an answer to your query, but I'd suggest you have a look at the Sears support site at www.managemylife.com. (Don't ask me, I didn't name it.)
You don't mention how old that model is, but if you have no luck there, try this site and it's possible there's one there or a similar model you can download that will provide the needed info for you.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 10, 2010 | Craftsman 8" Jointer, Stationary, 3 Blade...
Amount of fork oil for a XR 250 1985 model with 10 weight oil
13.4 ounces in each one. Or, with the fork spring removed and the forks compressed all the way, the oil level should be 150 mm (5.91") from the top of the fork tube.
Nov 09, 2009 | 1985 Honda XR 250 R
The fence in not sitting square to the table. If you place a square against the fence and the table there is a gap of about 2 mm and I don't how to fix it.
Does your saw have an adjustable/extension table. If so look on the backside where the other gear is located on a DeWalt there are 2 bolts holding this in place, what I do is loosen them up and with the square move the fence till it squares up and then snug the bolts, move the fence away and bring it back again to see if it repeats to square, if so tighten up, if not try again, if you don't have this gear give me the brand and model number and I will look into it further
Jul 09, 2009 | Craftsman 10" Table Saw
Planer Fence wobbly. Did set up 90 degree. However when planing stock it pushes over with result that stock is not square.
Most jointers can be set beyond 90 degrees. This allows boards to be beveled at angles over 90. There should be a locking handle or lever to hold it at the angle you want. If you want 90 degrees, adjust it to a framing square and lock it.
May 21, 2009 | Woodstock International Masonry Tools
Fence gets a slight bow in it when tightened
look at the far end of the fence for a nut that you can loosen slightly when in the unclamped position. It sounds as if you are clamping it so tight that you are bowing the fence
Mar 21, 2009 | Delta Saws
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Masonry Tools Logo
773 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
