Question about Electrolux Washing Machines
Error 20 with my Electrolux 8.5kg front loader washing machine
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
  • 160 Answers
SOURCE: e 20 error code on electrolux inspire washing
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
Posted on Dec 21, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Error code E40 on a Electrolux Front Loader Washing Machine EWF80743. What does it mean and how can I fix it?
E40 relates to door lock faulty or not closing - you probably need a new door lock, but check the catch on the door hasn't snapped off first. You will also get E40 if you try to start the machine with the door open.
Dec 01, 2017 | Electrolux Washing Machines
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
Electrolux front loader machine e10 error
I don't think you have all the correct error code. should be an "F" number before the "E" number. does make a difference. I want to give you the correct info.
Nov 27, 2015 | Electrolux Washing Machines
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
Washing Machines Logo
37 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
