Question about Brother HL-2040 Laser Printer
Drum light on will not print - Brother HL-2040 Laser Printer
  • 3 Answers
Its possible its not hooked up to your default current printer... try going to "start" then "settings" then "printers and faxes" then look for your printer name that you want to print with ex: Brother HL-2040 Laser should be there :D hope it helps
Posted on Jul 27, 2009
We have a Brother HL 2140 series the printer will not print. It has a new toner cart. The drum light is lit . Any suggestions?
This machine has a separate drum and toner cartridge. Replacing the toner does not reset the drum light. Double check that the light on is, in fact, the drum light, and if it is, replace the drum unit. This should resolve your problem.
In order to replace the drum unit, do this: 1) With the printer on and the drum light blinking, open the front cover. 2) Press and hold the Go button for about 4 seconds until all the LEDs light up. Once all LEDs light up, release the Go button. 3) Pull the print assembly out of the machine. 4) Push down the green lock lever to take the toner cartridge out of the drum unit. 5) Put the toner cartridge into the new drum unit. 6) Reinsert the print assembly into the machine. 7) Close the front cover and verify that the lights turn off.
It is theoretically possible that you could reset the counter without actually changing the drum by simply skipping steps 3-6 above, but I have never tried it before and Brother may be checking a chip on the drum unit to verify that it is, in fact, a new drum unit. If they are, you will have to actually replace the unit to make the light go off. I would strongly recommend against resetting the counter without actually changing the drum though, as your print quality will degrade and the machine may start to dump toner into the inside creating a rather large mess and a hefty repair bill.
Feb 28, 2011 | Office Equipment & Supplies
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
Drum light flashing
We have just changed our drum unit but the drum light is still flashing. The printer is printing though. Any suggestions?
Apr 12, 2010 | Brother HL-2150N Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Drum unit light showing and not printing
Try cleaning Drum or replace Drum,that's why the Drum light comes on
Sep 04, 2009 | Office Equipment & Supplies
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Drum error
Sounds like it's time for a new drum but, here's the reset procedure that should make the drum light go off and allow printing.
Make sure the machine is turned on and the drum light is blinking. Press and hold the "GO" button for 4 seconds (approx.) until all four lights are lit. When all four are lit, release the "GO" button. Make sure the drum light is off now. The drum is now reset.
THIS WILL NOT IMPROVE THE QUALITY OF PRINT as the drum will need to be replaced in order to do that but it will allow you to continue using the drum until it reaches and unacceptable quality.
Hope that helps you.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Brother HL-2040 Laser Printer Logo
224 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
