Question about Kenmore Refrigerators
Kenmore 203C2181p003 both frig and freezer quit cooling. Tried freeon but still not getting cool. What can we do?
What do you mean added Freon is the compressor running?
Posted on Aug 13, 2017
Testimonial: "I don't think so"
  • 2 more comments
  • Betty Baxter
    Betty Baxter Aug 13, 2017
    I don't think so
  • kennet
    kennet Aug 13, 2017
    how did you know you needed freon. i believe the compressor has to be running for you to add freon
  • Betty Baxter
    Thought it was running. But don't think so now
  • Betty Baxter
    What do you suggest we do now
  • 90 Answers
SOURCE: freezer not freezing
How old is the unit? Does it seem to have air circulating in freezer? Is the temp in the refrigerator side cold enough? One common thing is for the defrost heater to stop working which causes the freezer to ice up and stop circulating air. If you can put all items in a cooler and unplug the unit for several hours leaving the freezer door open. Plug it back in and see if it starts blowing frost again. That would indicate a bad defrost system. It can be several things but most common are the heating elements. If the defrost timer stops working you get the same results. If this does not produce positive results then it could be a weak compressor or gas leak. Best have a repairman check it or get a new one if it is the compressor.
Posted on Jan 28, 2008
capsman
  • 111 Answers
SOURCE: freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Posted on Aug 01, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Posted on Nov 17, 2008
peyton32034
  • 410 Answers
SOURCE: frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Posted on Jan 20, 2009
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
The freezer works well but the frig department will not get below 60 degrees
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 15, 2011 | Kenmore Refrigerators
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
Frig works for a while then does not cool unplug it then it works again. freezer freezes fridge does not cool
heatman101
Nov 19, 2010 | Kenmore Refrigerators
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Frig and freezer not cooling
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
Quit, but has power 106.56563400
is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Aug 26, 2007 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
