Question about Linksys Computers & Internet
How do i reset my xfinity modem and linksys router and then set up for wifi internet connection
  • 556 Answers
SOURCE: DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Posted on Dec 18, 2007
  • 141 Answers
SOURCE: Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is, it may be having conflict with the ATT modem. Change the wrt54g ip to
Good Luck
Posted on Mar 13, 2008
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
Posted on Jun 09, 2008
  • 67 Answers
Reset the DSL Modem and make sure the modem is setup for your DSL account information. You might have to call up your ISP for that information to be added. If that was done prior then the Router has to have the same information user name @ your or .com and password. for PPOE. Make sure the router has it MTU set to 1492 for DSL.
1. unplug the modem
2. unplug the router
3. between both of them wait 30 seconds
4. all PCs should not be on
5. plug in back the modem
6. plug in back the router
7. Turn one one PC
8. login to the router and make sure it connects to the internet
Since your using Gig Router make sure that the WAN is to 10 if you have 6Mbps plan 15 to 30mbp plan go to 100 for WAN.
If you're still having issues, then you need 3rd level service tech from your ISP to check the DSL back at the office side to see how that's connecting to your modem. If that checks out okay, then have line tech come out and check the DSL going into the house. If that checks out good then it could be the a problem with the new router you have there you have updated the firmware for it yet?
If you have then the modem could be the problem. These are the steps you need to take to trouble shoot the problem. Check all connections make sure they're plugged in correctly. Make sure all DSL filters are working correctly one bad filter can throw the DSL off. Check each phone connected to a filter to see if its clear.
Posted on Jul 31, 2008
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
Connect cable box to laptop
The Xfinity Cable Service is also an Internet service provider then you need a cable modem with a built-in wireless router.
Check with Xfinity and if they are also an Internet Service provider then they can also supply this cable modem/wireless router.
Jan 10, 2013 | HP Compaq Presario V5204nr Notebook
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
Dec 28, 2012 | Computers & Internet
Can't access internet, says I am connected but then says no internet connection
I think you should try to reset and reconfigure the Linksys router and see if that works.
If your Linksys router is old then you can also upgrade firmware on the router.
Connect your computer directly to the modem and make sure that you can access Internet directly through the modem.
Connect the modem and computer to the router. Open the setup page of the router and change the settings manually.
Try this website to setup your Linksys router manually.
I can also suggest you a Fiverr Gig where you can pay only $5 and get support for your Linksys router.
Jun 11, 2012 | Linksys Wireless-G Broadband Router
I just got xfinity cable internet that is connected through a linksys wireless g router and a arris cable modem. when i do a speed test at, my speed is only 2.7 Mbps. I believe it should be 16....
To correctly check James, I would connect a computer directly to the modem, and test at If that DL speed is fine, then I would connect the router, and plug a computer directly into the router and test again. If that number is fine, then you can narrow your issue down to WiFi speed only. All of the ports on the back of that router should be at least 100 Mbps ports. So that should not be the bottleneck. If your speed directly attached to the modem is slower than you expected, I would contact your carrier.
Mar 21, 2011 | Computers & Internet
Lost the internet connection on my laptop that worked before (Linksys wrt310n)
first check if you have internet with the modem if yes then you'll need to reconfigure the router. Contact router's manufacturer to assist you how to set it up.
Sep 14, 2009 | Linksys WRT300N Wireless Router
Connecting PSP to wifi
Change the primary DNS of your PSP to and secondary dns to
Apr 25, 2009 | Linksys WRH54G Wireless Router
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address -
DCHP - ON, Addresses - and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router -, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM or through this website.
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
