Question about Brother Sewing Machines
How do I open part 3 of brother 1120, zig zg button I want to change it to straight line
  • Brother Master
  • 11,500 Answers
If it is part of a programmed stitch, you most likely cannot change it. However, before the programmed buttonhole function, sewists were able to create buttonholes manually on their sewing machines. Not so difficult, really. And you can sew Step 3 however you want.
Posted on Aug 13, 2017
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
  • 1116 Answers
SOURCE: Brother VX 1120.... Machine is not making
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Posted on Feb 20, 2010
  • 22306 Answers
SOURCE: I have a Memory Craft 8000. The computer screen
the mechanism is worn that makes the needle head move in a zig zag fashion ,need to be taken to a repair man to have the worn parts renewed
Posted on Oct 06, 2010
SOURCE: machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Posted on Mar 21, 2012
SOURCE: how do you set the zig zag stitch on a Jones
I have been gifted a Jones ym260g. Does it do straight stitch and if so, how?
Posted on Jan 16, 2014
Brother 888
Here you can download the manual
Nov 29, 2017 | Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
My Brother LX 3125 does not sew zig zag stitches correctly. It zigzags about an inch then straight stitches an inch. I have changed the thread, needle, bobbin ?????
Nov 23, 2009 | Brother Sewing Machines
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Zig zag problems
oh my i think you need to open your machine sir. i already tried it. kinda hard to explain it here
Sep 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
