Question about GE Home Security
We have a GE Networx NX-8V2 system but it has not been in operation for over 3 years. We are getting an alert for "Power Control Trouble". Any way to stop it? We do not have any info on this system.
SOURCE: GE SIDE BY SIDE FRIDGE.
I ACTED TOO FAST... WENT THROUGH MY PAPERWORK & HAD INSURANCE ON MY APPLIANCES. I SORRY TO BOTHER YOU, BUT GLAD YOU ARE NEAR BY IN CASE I EVER NEED YOU LATER.
THANKS!
Posted on Aug 05, 2008
SOURCE: Tomtom still charges but traffic receiver stopped working
I'm using the TomTom Go 730T - I think this is the latest and the last TT with Traffic because TT stopped supplying this option. I'm having the same problem from time to time but a reset helps. Just press the Reset button and after restarting the traffic option is back. Janos
Posted on Aug 08, 2010
Testimonial: "That worked! Thanks"
  • 74 Answers
SOURCE: hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Posted on Aug 23, 2010
  • 74 Answers
SOURCE: I have a networx nx-12 (d.a.s.) home alarm and the
This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
Alarmprofessor.com
Posted on Sep 05, 2010
steve_hillin
  • 44 Answers
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Posted on Mar 05, 2011
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
I dont seem to get power to control panel. battery also not charging
These alarm panels receive 16.5 VAC from a small wall adapter that is wired into the keybus and labeled 'AC'. Have a certified alarm company or installer check your system for faults and get things in order.
Mar 02, 2011 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
Can I adjust the volume on my GE Networx NX-148E keypad?
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I have a networx nx-12 (d.a.s.) home alarm and the power light is flashing. What does this mean and how do I fix it.
Alarmprofessor.com
May 16, 2010 | Home Security
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Home Security Logo
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
