The Please Run Channel A sign is flashing all around the screen. What does this mean?
What does it mean when the car wont start and the light around the park sign flashes..and the outside lights flash
Well usually if the outside lights are flashing, the anti-theft alarm has been triggered. But the horn blows too in most cases.
Jan 11, 2016 | Cars & Trucks
No pic please run channel auto scan
It means it is not detecting signal etc.
If you had a power outage unplug the set for a short period of time and plug it back----if using a box for signal do the same.
This may allow set or box to reboot and function again.
Also you can try to hook a DVD etc to a rear audio/video input to see if that works.
Mar 31, 2012 | Televison & Video
How do I get the Dreamcast to work on a Hannspree HSG1116? I turn it on plug it in, everythings in tight yet I get "No Signal" flash around the screen on every possible channel. The Dreamcast...
Lemme guess.. Your trying to run it from the cable connection and not av-cables?
It's a pain trying to get a cable connecting game consoles working on newer televisions with a digital tuner installed. Your gonna have to go the annoying route of searching for the channel through your setup screen or you might be able to access the channel that it is set for using your remote for the tv (channels 3.0 and 4.0 still work with older consoles using the cable plug).
Just type in either of those channels with your controller unless you went the search route.
If your playing the Dreamcast with audio-video cables, you would have to find exactly which input your using.
nubatman.gifRF cable - Connects to your cable input.
nubatman.jpg AV cables
Sep 11, 2011 | Video Game Consoles & Games
What this sign mean caps lock light is flashing on off ,screen blank hp compaq presario cq61 please tell what I do
Find link below list of errors
May 07, 2011 | Computers & Internet
Sign keeps flashing " please do auto channel search "
TVs require a channel search when first started up/turned on so it can generate a channel list. check in the manual of your tv for instructions on how to do this.
Jun 17, 2010 | Insignia IS-LCDTV32 32 in. Television
Flashing Text Message Sign- Not New Msg
it means your inbox is full.. in most cases anyway or that your phone is stuck on the text message icon.. it will go away afterawhile i had the same problem with my lg
Sep 04, 2009 | LG Neon GT365 Cell Phone
Message icons
flashing envelope means your msg in SIM ARCHIVE is full.
wap sign means you postpone the dowloading of wap session sent toyou.
Feb 13, 2008 | Sony Ericsson T610
Flashing warning
Your CR1616 battery is not installed properly. +sign to +sign
Dec 22, 2007 | Video Cameras
Protect and Push power
A sign flashed across the screen "Protect and "Push power" Please what does this mean? and what do i need to do to fix it?
Fabio Catarcione
Dec 22, 2006 | Sony DHC-MDX10 Shelf System
Televison & Video Logo
Top Televison & Video Experts
