Question about Miscellaneous
Looking for help ! The fan on my Zephyr Venezia Stovehood Fan Model ZVE-E30AS has stopped working.
I has 6 speeds up to 750 CFM. Lights work fine. It is over 10 years old. I have previously torn it down to change bearings twice over the years so I am quite familiar with the guts of it. This has me stumped a bit. Unfortunately, I cannot locate the wiring diagram nor a repair manual. I am trying to find which electrical component is bad. The issue starting happening after a neighborhood power glitch which also blew out my Verizon FIOS requiring a new distribution box. When you push the fan button there is no noise at all, no hum, nothing. I did a complete teardown, used jumpers, and this is what I determined: 1. Switch continuity verified OK 2. Circuit board output to the fan motor with motor unconnected is OK at 120v. 3. Circuit board output to the fan motor with motor connected is NG at 0v. 4. Starter capacitor 25 uF tested OK on meter, spike on meter repeatedly as you switch leads. I do not have the right meter to test the uF tolerances. The cap was physically perfect with no bulges, etc. 5. Hooked up the fan motor direct to 120v with the starter cap in place and the fan ran perfectly. Although, it runs only at the highest speed which I recognize from the sound. 6. I suspect something on the circuit board is sensing something not right with the motor/cap and therefore shuts the voltage off to the motor. What do you guys think ?
  • 132 Answers
SOURCE: 2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Posted on Jul 30, 2008
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
SOURCE: Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Posted on Feb 19, 2009
  • 12744 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
SOURCE: fan stopped running. no power to the fan (ie, no
You may find the parts that you need at the following web site...http://www.eceilingfans.com/
They have all of the capacitors there. All you need are the number of wires and the capacitor micro-farad ratings.
Posted on Oct 22, 2010
Vent won't work
Check to see that there is power to the vent hood. Sometimes a breaker will not reset correctly.
Feb 23, 2010 | Zephyr ZVE-E365 Venezia Wall Hood
Change a bulb in my kitchen hood
good day,
hope this link below will solve your problem.
kitchen
Jan 09, 2010 | Zephyr Venezia ZVE-E30 Kitchen Hood
Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Would you know how to replace a bulb for a Venezia hood. I can't find the exact specs for the replacement bulb JDR E27 110V 50W
Chris, I googled and found this
http://www.plasmaled.com/household_led_light_bulb.htm
probably available at a lightbulbs unlimited or other lightbulb store.
Maybe even a Home Depot or Lowes.
Jan 04, 2009 | Zephyr Venezia ZVE-E30 Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Speed control on fan
It means that the filters on the hood need to be cleaned. You simply pop them out and can wash them in the dishwasher. Once clean, dry and replaced, you hold down the fan speed button (the second button from the left or " - " minus for more than five seconds.) When you first hit the button the A will appear, hold the button when the letter disappears, the timer has been reset until time for the next cleaning. The microprocessor in the system will flash every 30 hours of operation.
May 07, 2008 | Zephyr Venezia ZVE-E30 Kitchen Hood
Flashing "A"
Press and hold the (-) button with the unit off untill the (A) clears. It's a 30 hour timer to remind you to clean the filter
Mar 11, 2007 | Zephyr Venezia ZVE-E42S Kitchen Hood
Eletrical problem
I have the problem of the lights not shutting off. It just happened today about after 6 mo use of the hood. where can I get support? Where can I get a new control unit? Venezia Zeneth
Jan 06, 2007 | Zephyr Venezia ZVE-E30 Kitchen Hood
Miscellaneous Logo
21 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
