Question about Stihl Garden
I need a parts diagram for stihl 028av woodboss
4 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
  • 67 Answers
SOURCE: stihl 026 woodboss chainsaw. i'm trying to change
Loosen the nut on the the top cover, it has a rubber gromet around it. Then lift the cover off. Now youcan remove the plug
Posted on Apr 08, 2010
perkins48
  • 14406 Answers
SOURCE: I need a parts diagram for stihl 009l chainsaw
Stihl does not have a parts list anywhere,they have it where you have to go to them for anything,spark plugs is one thing you don't buy from them,6.95 versus 2.95 at Autozone,ngk .
Posted on Dec 12, 2012
Hole in fuel tank my 024 woodboss stilh chain saw
get a new tank from stihl spares
Jan 29, 2018 | Garden
Parts diagram for a stihl ms 461
the link I attached has a slideshow at the bottom of the page with all the diagrams you should need.
have a nice day :)
https://chainsaw-workshop-manual.com/product/stihl-ms-461-parts-list-manual/
Jul 14, 2017 | Stihl Garden
Stihl 028 av super not oiling
Part of the routine service while sharpening the chain and adjusting the chain tension is to remove the guide bar to clean the slot and to clean the side of the saw case of any and all impacted crud. This impacted crud many times inhibits the oil flow to the bar causing it to appear as though the oiler is not oiling. Make sure you clean the discharge port of the oil pump...it will be the opening that aligns with a slot in the bar to transfer the oil to the chain.
After cleaning and reassembling, start the saw and rev it up for 2 to 3 seconds and observe the bar tip as it is aimed against a clean piece of cardboard. If the oiler is working, within this time frame, a thin film of oil will appear as it is slung off the bar tip.
Nov 25, 2015 | Stihl Garden
Woodboss 028av. I removes the air filter. on the left side there is a tiny plastic tube with a tiny spring inside it. what is this for
I think you are looking at the fuel tank breather pipe. The AV just means; anti vibration. My Stihl parts list shows it as 1117 350 5800 Tank vent.(Plastic Tube) And 1120 358 8105 Vent Insert. Its basically a small plastic tube with a restrictor in it that vents the tank. Only repair it if there is gas leaking. A local shop would help or go online.
Nov 03, 2014 | Garden
Stihl diagram parts list for fs85
your local stihl dealer can email you a parts diagram...
Aug 28, 2012 | Stihl FS 85 Weed Eater
Stihl 028 woodboss runs fine for a tank of gas.
new air filter or wash it out with petrol to remove oil from the filter
Aug 03, 2012 | Stihl Garden
MS 250 Easy2Start WoodBoss parts list, can't find it on the net. want to go through this used chainsaw and replace the parts that are worn, like the rubber mounts
Jerry is correct!
Stihl considers ALL OM parts, IPLs and shop manuals proprietary.
Every time they become aware of an on line source they force its removal. You are encouraged to try to obtain an IPL here:
Stihl.com - Contact Us
http://www.stihlusa.com/contact.php
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Lou
Feb 25, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
