Question about Bosch Ovens
Bosch oven mode buttons beep twice and don't activate
New oven; can change setting, lock panel, but modes beep 2x and won't activate (all modes)
  • 35 Answers
SOURCE: Oven keeps beeping and displaying F1
this code is suggesting that you might need a control board.
Posted on Jun 25, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: oven door lock
    Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
    Posted on Nov 18, 2008
    • 10865 Answers
    SOURCE: cannot unlock oven frigidaire electrolux gallery series
    hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
    and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
    let me know how u make out with this as I can offer additional help if needed.
    Posted on May 28, 2009
    • 14 Answers
    SOURCE: ge profile oven is in lock mode not able to turn
    Hold the "lock" button for three seconds.
    This is the way mine works, yours is probably the same way.
    Holding the "lock" button for three seconds changes it from locked to unlocked and ALSO from locked to unlocked.
    Posted on Nov 16, 2009
    The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
    In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
    Feb 02, 2016 | Bosch Ovens
    My oven displays error code 5AB
    I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
    Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
    The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
    SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
    If power is disconnected a new 72 hours cycle will start.
    Depending on the model, there may also be a beeping sound when you try to operate the oven.
    Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
    If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
    on Mar 05, 2010 | Ovens
    I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
    the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to and look up your model number for your manual. good luck
    Dec 27, 2015 | Bosch Ovens
    How do I change Bosch oven clock from military time?
    We have an older Bosch Oven (maybe circa 2010), and the way to access the special settings is to hold down the "Temp" button for 2 seconds which reveals a hidden menu of goodies. I made two changes in there--changed it back to 12 hour instead of military time as well as disabled the annoying beeps every time you press a button. Manual is here:
    May 17, 2014 | Bosch Ovens
    Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
    Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    Gibson oven door is locked after attempting to do self-cleaning.
    Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
    Sep 24, 2012 | Ovens
    I have a faure oven which is in safe mode . How do I get it to function.
    press and hold the temperature button and simultaneously hold the 'temperature duree' knob to the + or - position until you hear a beep. This locks and un-locks the child safe mode
    Jul 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
    Westinghouse oven pof668 in auto mode - how do I get it out of auto mode (am renting this property). Oven and grill are not working as power was off until recently
    Most models won't work when on Auto. Generally there are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). Press this button and it should go back to manual mode and allow you to use the oven.
    What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, w
    hile I can't find the specific manual for your model, there is a westinghouse oven manual here:
    and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
    Jul 28, 2011 | Ovens
    Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
    Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
    Feb 11, 2011 | Ovens
    Fan won't turn off & upper oven work in Manual mode
    This sounds like a control panel issue, you may have to replace it, about $300.00
    Jul 09, 2017 | Bosch HBN 455 Stainless Steel Electric...
    Ovens Logo
    Top Bosch Ovens Experts
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
