Question about Cell Phones
How to maintain a connection between my phone and WiFi
Wifi issue. Need help
You may have a defective Wi Fi radio card in the laptop. You might want to replace it.
Apr 10, 2014 | MSI GE70 APACHE PRO-061 I5-4200H 2.8G 8GB...
How to connect to wifi?
Goto your phone connection settings:-
Select -> Wifi -> On.
Search any Wifi Network and Connect..
Feb 26, 2013 | Samsung Omnia Pro B7320 Smartphone
How do i connect my phone tomy computer using wifi
this is the universal problem wifi requires a no separate from all devices connected to it he cannot connect a phone or any other wifi device a wifi enabled laptop or computer you can't connect to wifi printer to computer either in the same respect to the phone
Apr 01, 2012 | Sony Ericsson Vivaz Cell Phone
Tethering lg phoenix no connection
Expecting your PC (having no inbuilt/internally installed WiFi adapter) to pick up tethering/hotspot WiFi signal (from your phone) without a WiFi adapter attached/connected into your PC's USB port is the same as expecting your PC's low battery to charge to full capacity when the power cable is not connected to the power supply point.
Get WiFi adapter connected to your PC first and then attempt to connect to your phone's wifi tether/hotspot
Nothing is wrong with your phone please
Oct 12, 2017 | Cell Phones
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Wireless adapter connects at 54mb but drops to 1mb w/any dataload
Usually, a device will renegotiate a slower speed to compensate for interference. slower speeds are sometimes the most reliable. Its possible to change your wifi channels and try to get one that has less interference, and maintain a stronger signal. You might also want to ensure that any cordless phones in your area are NOT on the same frequency range as your router, because as soon as "Old Great Aunt Mildred" calls you or your neighbor, your wifi goes bye bye.
Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
Apr 10, 2009 | Computers & Internet
Internet connection
The problem may lie with your WiFi adapter on the 2nd computer.. these days NICs (adapters) have a Power Off capability and they will go to 'sleep' to save power.. you can try to resolve this through the Device Manager > Network Adapters > and the Properties of your WiFi adapter.. look for a tab on the Properties named Power Management..
Otherwise, it this is occuring on the WiFi Access Point, look for something in the interface to maintain Persistent Connections.. Since I do not use Netgear, I would have to find the manual to be sure.. but lets try the first option before we go on..
Dec 17, 2007 | NetGear RangeMax Next Wireless Router...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
