Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV62 K IX UK - dispenser does not open
The Indesit DV62 K IX UK dishwasher dispenser does not open and the tablet stays inside at the end of the program.
I know this problem is not new, but I'd like to fix it by myself. I have found the electromagnetic mechanism inside the front door that releases the latch of the dispenser. I need to measure with a multimeter if the voltage appears (which would mean the coil got burnt) or not (the dial is faulty).
How do I easily find a proper dial position that applies voltage to the dispenser coil? And if the dial is in the right position, is the voltage being applied until next position or just for a 'millisecond'? Any schematics or hints?
Thanks very much for your help.
5 Suggested Answers
  • 236 Answers
SOURCE: Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Posted on Jun 11, 2007
  • 27 Answers
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Posted on Jun 26, 2007
On a D61 I managed to solve this without dismantling the door!
If you look carefully in the hole where the white catch fits you can see the shaft it rocks on. I put a small screwdriver in here and levered it forwards. It didn't want to stay so I put another screwdriver behind the white plastic bit, removed the original screwdriver, and continued to prise the white plastic bit forward until it clicked and stayed. I reckon it is caused by slamming the door. Don
Posted on Apr 04, 2010
espressonist
  • 1711 Answers
SOURCE: indesit idl 535, washing on usual cycle but not
Your problem is very clear, you need to replace the wash tank heating element.
Posted on Aug 17, 2010
Dispenser door not opening, therefor tablet not being dispensed nor is rinse aid
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 04, 2011 | Indesit 23 in. DV62 IX Built-in Dishwasher
Rinse aid light
First check in the dispenser is a knob that has an arrow on it see where this points it should only have to be set on one or two normally any higher and you will use more rinse aid if it is on one or two then get a tech to check it it may need to be replaced
Jan 21, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
DV62 WH UK
pay me 9.99 dollars and you can have the info cheers.
Nov 19, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Door catch not sprung back
should be able to flick it out with a screw driver...sounds like part of the catch is broken
Oct 03, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dsihwasher Door adjustment
Turn the spring tension screw anti clockwise to reduce the spring strength Regards Engineer
Jul 27, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
MICRO SWITCH
if you mean the door lock micro switch the is only two connections you can not go wrong Regards Engineer
Jul 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit dishwasher DV62
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
48 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
