Question about Cell Phones
At the bottom of the phone are two buttons that do not light up. Hoe can this be fixed?
Bluetooth in my car is not syncing with phone
go to some one that know hoe to prepare the bluetooth you have or use manual. you should get red and blue light to prepare tham to work togther by pressing one buttone. try and see.
Sep 27, 2013 | Apple iPhone Smartphone
The 'alt' symbol is stuck on my blackberry 8520 and now the phone is useless!!! Any solutions on hoe to remove the 'alt' symbol?
Have you tried compressed air?
Also, you can remove the entire keyboard (not individual keys) and you might be able to fix it or clean the key once its removed. you can find lots of videos on youtube showing you how to remove the keyboard
Apr 13, 2011 | RIM BlackBerry Curve 8520 Smartphone
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
I want to install a phone jack where the old phone is direct wired but I don't know how to get the phone apart to disconnect the wires. It is an old black rotary phone that hangs on the wall.
Look for screws on the bottom of the phone. Unscrew them. The top shell cover (excluding the dial) should be pulled up. Loosen the screws that hold the wires attached. To reconnect match wire colors.
Hoe it helps.
Sep 15, 2009 | Bell Lands Phones
when ever the phone got wet, it will damage the mother board of the phone, it will cause corrosion that needs to be fixed or replaced.
Jun 26, 2009 | Samsung SGH-G600 Cellular Phone
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
Fix time
log in thru a telset and when the 4 lights light up on the right hand side of your phone hit the bottom right button till you get to time and date and you change there.
Mar 18, 2008 | NorStar T7316E Corded Phone
Nokia 6133
I believe that is the bottom right square on the top field. The red one one that has a small dot next to it. Make sure the battery is charged. If in doubt, turn it on while connected to the charger.
Nov 26, 2007 | Nokia 6133 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
