Question about Casio Exilim EX-Z77 Digital Camera
Battery charge blinking and the camera doesn't turn on
  • bianca78br Jul 28, 2009
    Already tried to replace the battery...
    Brigadier General:
  • 4,090 Answers
Try replacing the battery
Posted on Jul 27, 2009
My Kodak M531 doesn't charge its battery
I would try a new battery before a trip to the camera shop as the cost of a battery for this model is far less money than a trip to the repair shop.
Nov 04, 2012 | Kodak Cameras
Camera will not charge, shows blinking orange but will not turn on... when it does, it's to a "battery exhausted" screen or the lcd display with a low battery symbol. Also doesn't show on...
It could possibly be the battery or the charger itself.Try purchasing the charger it self.Use the old battery to see if it will charge it. If it does not charge you may have to purchase a new battery.as well.
Sep 06, 2011 | Nikon COOLPIX P100 Digital Camera
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
My camera wont charge, when i plug in the camera the green light will blink several time and then disapear
It's probably a worn out battery. The batteries are good for 150-300 charges. Every connect is a charge. Doesn't take long.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
I have 3 blinking red lights
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 10, 2010 | Kodak EasyShare One Digital Camera
When i try to trun on my camera it will blink on then go right back off.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EASYSHARE M763 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
326 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
