52.0 scanner error - Office Equipment & Supplies
Nikhil Gedam
  • 87 Answers
SOURCE: 52 scanner error problem
Perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
If this step does not resolve the issue, please repair/replace the printer.
Nikhil Gedam
Posted on Dec 22, 2008
Nikhil Gedam
  • 87 Answers
Super NVRAM init
1.
if the above step does not resolve the issue, please repair/replace the machine
Nikhil Gedam
  • 121 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
nonontech
  • 4737 Answers
SOURCE: scanner error 52
If you can open it, please reseat the scanner flex cable after turning the machine off. For full details on how to troubleshoot, please refer here.. Hp error code 50 - 59 Good luck. Thanks for using FixYa.
Posted on Jun 05, 2010
seeker5211
  • 1089 Answers
SOURCE: 52 scanner error. Turn off thenb on
52 is an internal scanner hardware error.
Unplug printer, wait 30 seconds, plug it in and power up.
Problem still there...make sure printer is plugged into wall outlet, not surge protector.
If error persists you will have to get the laser/scanner assembly replaced.
We arn't talking about the scanner/copier assembly at the top of the printer. This is the internal laser/scanner that is used for all your printing.
Posted on Jan 12, 2011
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Hwo do i repair error 52 in hp leserjet pro 400 m 410 dn
52 error is scanner related not formatter. HP has had issues with some serial number ranges of this printer having bad scanners which they will replace. You should contact HP regarding this problem.
Sep 09, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
Jan 12, 2011 | HP LaserJet 3050 All-In-One Printer
Critical error messages 52 Scanner error
Basically, for most of HP printers error 52 means laser-scanner motor incorrect speed...
Try to replace laser-scanner assembly (visit authorized service)
Good luck!!!
Dec 14, 2010 | HP LaserJet 3055 All-In-One Printer
Scanner error 52 during opening scanner bulb warming up error scanner error 52 what should i do
Jun 05, 2010 | HP LaserJet 3330 All-In-One Printer
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP Laser Jet 4 Plus error code 52 What do I do now?
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Jan 18, 2010 | HP LaserJet 4 plus Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Error 52
I think this will have to do with Hardware issues in terms of the "52 scanner error". According to the service manual, this has nothing to do with the ADF, but has to do with the Laser Scanner. The cable to the laser scanner is bad or the laser scanner itself is broken. If the cable is ok, then the Laser Scanner Assembly part number is RM1-0171. I think you could find it if you google it.
Oct 22, 2007 | HP LaserJet 3030 All-In-One Printer
k24674
jasbo
jasbo
