Question about Singer Sewing Machines
Repair 306 singer motor - Singer Sewing Machines
My Singer sewing machine motor burn out .model 132K6 ,where can i get a recondition or new motor ?
singer repair agent
many singer motors are generic so ask other repair shops for a replacement motor
May 20, 2018 | Singer Sewing Machines
I bougth a Singer 7258 in USA (120V) and i turned on in UK (220V) without voltage transformer, and now it does not work. sombody knows how fix it?
sadly you have burnt out the motor or foot control . and the only fix is to replace whatever you burnt up . take it to a repair center locally .
Mar 23, 2016 | Singer Stylist 7258 Electric Sewing...
Professional XL _ 1. Where can I get a replacement motor?
Perhaps through a singer dealer or any good repair shop
Sep 25, 2015 | Singer Sewing Machines
I have a SINGER ingenuity Sewing Machine I want to put it into my SINGER SEWING MACHINE DESK MODERN OAK CABINET 201 15-91 115 306 319 27 66
1. Find two holes on the back side of the machine towards the very bottom of the machine. Small screws are inserted that need to be almost removed.
2. There are small pegs attached to two hinges (towards back of table where opening is). Stand them up towards the ceiling. (Possibly need help)
3. The sewing machine will face the front of the machine towards the floor and the bottom of the machine towards yourself. It must be held while doing this.
4. Aim the holes of the machine towards the holes and lower the machine. As the pegs go through the holes of the sewing machine the screws need to be tightened.
Sep 21, 2015 | Singer Sewing Machines
Where can i find needles for a singer 306k machine ?
What type of material are you going to be sewing? Sew-Classic has 10 needle packages of the size 12 and size 14 needles for the Singer 306 for light (not fine) and medium weight material. (It's a 206x13 needle for the single needle. The twin needle is a 306x3.) See http://shop.sew-classic.com/206x13-Sewing-Machine-Needles_c46.htm .
http://www.allbrands.com/products/15221-schmetz-german-206x13-flat-shank-needles-100-size has some notes on alternative needles. The site has boxes of 100 size 14 and size 12 needles. (The size 14 needles are out of stock due to delays on the manufacturer's side.) https://www.college-sewing.co.uk/206X13-SIZE-90-PACK-OF-10-NEEDLES (size 14) needles in stock.
Unfortunately, I do not see any twin needles available for the 306K. I hope this helps.
Feb 20, 2015 | Singer Sewing Machines
How can i reassemble the lower case of my singer 2010 superb sewing machine
Most machines you have to put things together and take them apart in a specific order. Look for tabs that fit in specific holes. Also most of the time the parts that go over the motor go first, then front sections and then the back. You can contact singer directly and they can walk you through it in a live chat. Otherwise I have had really good luck working with the people at the link I attached. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Dec 09, 2014 | Singer Superb 2010.CL Sewing Machine
Singer Quantum XL1000 Feed Motor
It is called a "stepping motor." You may be able to find a generic model or one from a donor machine that would work.
Singer XL 550 Service Manual Basic Positioning Of Zigzag Step Motor
Singer XL 1000 List Of Parts
You might try contacting some of the online vendors for advice:
http://www.sewingpartsonline.com/singer-quantum-xl1000-sewing-machine-parts.aspx
Service Manual Singer Quantum XL1000
Apr 02, 2017 | Singer Quantum XL-1000 Computerized Sewing...
201-2 singer sewing machine plug wireing diagram
Any of the older Singer manuals will give you this info...here's a PDF for your machine...
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-model-201-sewing-machine-manual.pdf
If that doesn't help scroll down on this page there's a simple diagram on there.
http://blog.sew-classic.com/2009/11/30/replacing-the-wires-on-a-singer-button-foot-motor-control.aspx
Aug 31, 2012 | Singer Sewing Machines
The motor on my Singer sewing machine model 7444 has stopped entirely. I am outside the US and must fix this myself. I am in a very remote location. Please describe how to remove the cover (all the screws...
I think, if I were you, I would go to www.singer.com and click on the country where you are located and call them, to get replacement parts. They are located all over the world, not just the USA. They can get you a new motor or advise you where to get one and how to open your case without damage. Most of the machines today use a disposable motor and replacements are not that expensive, not like years ago. And you would want the same voltage etc. Good luck
Nov 20, 2010 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
