Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Canon image class mf5750 legal size paper
Canon image class mf5750 does not allow us to print to legal size paper and gives us a cassette error message
  • Anonymous Mar 18, 2014
    paper size error
  • 92 Answers
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <canon image class mf5750 legal size paper - la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. canon image class mf5750 legal size paper - la.giflass="h_mi">Press <la.gif> or <ra.gifPress <la.gif> to select [PAPER SIZE], then press <Set>.
  4. Press <> or <ra.gif> to select the appropriate paper size (LTR,canon image class mf5750 legal size paper - white_square.gifA4, B5, ENVELOPE, or FREE SIZE), then prescanon image class mf5750 legal size paper - la.gifSet>.
    black_dot.gif When [ENVELOPE] is selectecanon image class mf5750 legal size paper - white_square.gifwhite_square.gif Press <la.gif> or <ra.gif> to select thcanon image class mf5750 legal size paper - la.gif of envelopes (COM10, MONARCH, DL, or ISO-canon image class mf5750 legal size paper - ra.gifhen press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range icanon image class mf5750 legal size paper - la.gifTICAL SIZE]: 127 mm to 356 mm (5" to 14") Press <Set>. canon image class mf5750 legal size paper - ra.gif the steps above to specify both vertical and horizontal sizes of the paper.
  5. Press <Stop/Reset> to recanon image class mf5750 legal size paper - la.gifo the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you cancanon image class mf5750 legal size paper - la.giffy the paper type according to the followicanon image class mf5750 legal size paper - ra.gifecifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  2. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
  5. Press <Stop/Reset> to return to the standby display.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
My printer says check paper size it has on screen cassette a4 how do get it to legal size
Open the paper tray and extend it to legal, then place legal paper on the thing. It is the only way to solve this problem
Jul 04, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
We have a Canon Image Class MF3240 Copier/Fax/printer/scanner. We are receiving error A4-load proper paper. We are loading with 8 1/2 by 11 paper. What is this error telling me?
The problem is on the computer, not on the printer.
"A4" is a paper size, just like "Letter" and "Legal".
You probably have your software application, such as Excel, Word, etc., set to paper size = A4.
Do this in your program on the computer:
[File]
[Page Setup]
[Size] "8 1/2 x 11"
... and print your document again.
Mar 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
How can I set up the paper size from letter to legal when i print? I am using the canon image class d340.
1. Access Page Setup in your application and set the paper size.
2. Do File -> Print and click the Printer Properties button to set the paper size before printing.
Nov 24, 2008 | Office Equipment & Supplies
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
795 people viewed this question
old marine
old marine
