Question about Electrolux Dishwashers
My dishwasher is leaking from front lower right corner
Electrolux ewdw6505gs0
SOURCE: GE Nautilus
Our dishwasher had the same problem and it turned out that a broken glass had pierced the seal around the motor and water was leaking into the motor and out onto the floor So we had to replace the whole motor. Luckily it was covered under warranty.
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: leaking dishwasher
call the manufacturer, some dishwashers have a lifetime warrantee against leaks
Posted on Jan 31, 2008
SOURCE: Fisher and paykel 913T soft touch dishwasher leaking
I had the same problem and replaced the door seal. You need to remove the front door to do this. Requires some 'handyman' experience.
Posted on Jul 01, 2008
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
  • 3247 Answers
SOURCE: My dishwasher is leaking out
Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Posted on Jan 10, 2011
My electrolux dishwasher model EWDW6505GS0 will not turn on. The electronic display only indicates "Welcome" for a split second and then goes out and nothing lights up on the panel and cannot get it to...
Good Afternoon Will, thank you for allowing me to assist you!
How long did you leave the breaker off? It is important to wait roughly ten minutes and then your dishwasher on. If resetting the power does not correct the issue, then it sounds like your dishwasher could possibly be experiencing a communication error with the control board/panel or a potential wiring failure. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jan 11, 2014 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
Frostfree freezer leaking from lower front
From what you have described, without a model number, it sounds like the unit is leaking from possibly going into a defrost cycle. Check to see if you have any ice build up that is now melting or "slushy" in that general area. Water tends to run along the nearest plastic ridges and parts til it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire Professional Series...
Front door lower right corner leaks on operation
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Dec 26, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Leak in right front
Leaking Dishwasher
heatman101
mj
Sep 11, 2010 | Electrolux EWDW6505GS Fully Integrated...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
