Question about Humidifiers
Fridgidaire humidifier KNOO707918 - when was this manufactured?
Cool Mist Humidifier 1.3 gallon Well at Walgreens users manual
For a manual, try Googling (brand)(model)(manual) without parens. Some humidifier manufacturers specify use of distilled water to prevent mineral deposits.
Mar 30, 2018 | Humidifiers
I have a Idylis #0484758, coolmist humidifier with a broken tank, can I buy a tank for this humidifier?
No idea. Ask the manufacturer if they sell spares or go beck to your supplier for advice.
Nov 02, 2017 | Humidifiers
Why does my machine keeps turning off
This question needs to supply more information than it currently does. Who manufactured your humidifier? Model of your humidifier? Details about when it 'shuts off', such as water level, temperature, etc.
Most humidifiers are designed to shut off when conditions reach an unsafe condition, such as water level too low. Generally this is sensed by some sort of float telling the device to shut off. Another method used is by monitoring the temperature in the device, after all 'humidification' is done by evaporating water into the surrounding air. If the temperature rises above 212 deg f (boiling point of water) it thinks there isn't any water left to add to the air so it shuts off for safety reasons.
The best course of action is to contact the manufacturer directly for details.
Apr 02, 2015 | Humidifiers
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
How do i use a challenge humidifier s35u-b
The challenge 3.5 ultrasonic humidifer is very similar to the Vicks one on the inside (same nubuliser etc.). It's manual is here http://www.kaz-europe.com/wp-content/uploads/VH5000E_OM_01JUN11.pdf and its made by www.kaz.com - they manufacture humidifiers under a few different brand names.
The vicks cleaning instructions are more stringent, I think because they are marketing this as a children's humidifier - they recommend bleaching the unit.
Mar 10, 2012 | Humidifiers
It's just not working..no mineral buildup..the orange light won't go to green..2 month old humidifier in otherwise great shape..any ideas?
At only two months old, it's still under warranty for either repair or replacement. Best thing to do, is contact the manufacturer and have your Proof of Purchase handy.
Apr 22, 2011 | Vicks V745A 1 Gallon Humidifier
Cow humidifier sparked and smoked.
Contact the manufacturer, and the retailer let them know about it and try for a refund.
Jan 26, 2009 | Crane Cow Humidifier
Vicks v5100 need helpa to operate
Go to this link: http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Details.
Download Product Manual [205kb PDF]
You will need Adobe pdf reader to view the pdf file. Do you need Adobe Reader? Download it for free at this link:
http://www.download.com/Adobe-Acrobat-Reader/3000-2378_4-10000062.html
Once the pdf loads in Adobe you can print the manual.
Good luck & best wishes.
please vote...
Mar 06, 2008 | Vicks Ultrasonic V5100 Humidifier
Replacement tank for Vicks Cool Mist V3500N
It doesn't look like they sell any replacement parts for this machine. I would call the manufacture and see if they will sell you one.
Good Luck.
Feb 05, 2008 | Vicks Cool Mist V3500 Humidifier
Humidifier leaves film everywhere!
I talked to Kaz, a manufacturer of humidifiers, and they said this is referred to as "white dust". It's simply the minerals from your water settling on your furniture...I had to same problem so I called the manufacturer.
He said it's not dangerous but that I should use distilled water in my humidifier from now on since my water will always do that. He also stressed the importance of cleaning the unit weekly with a bleach and vinegar solution per the manufacturers specs.
Nov 21, 2007 | Air-O-Swiss 7133 Humidifier
Humidifiers Logo
139 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
