Question about Poulan Garden
Where to buy replacement front wheels for a 19 year old poulan pro model pp2265a
    Master:
  • Poulan Master
  • 645 Answers
These will need to come aftermarket. Companies usually only stock parts for up to 10 years.
Posted on Dec 05, 2017
dontbother10
  • 2220 Answers
SOURCE: need chain adjustment wheel part # for poulan pro
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Posted on Nov 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: my 2 cycle poulan pro weed eater won't start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see day light through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 1015 Answers
SOURCE: Caloric Gas Range Model #355 19 years old. Is
Being that your range is 19 years old it might be a bit difficult to find the correct igniter but not impossible. The model number that you gave is not giving any good results. You can go here http://www.repairclinic.com/Caloric-Range-Stove-Oven-Parts?s=b74a13c249 and look at these igniters to compare with the one on your range. You might get lucky and one of these could be a replacement that will work. Most local range parts suppliers are very helpful on locating hard to find parts but you may need to remove the igniter and bring it in so they can match it up in their catalog. You might also be able to find the correct igniter if you use the part number on the ceramic igniter housing to do a parts search with. Most 20 year old ranges use a standard "flat style" hot surface igniter but there are different OHM ratings for some igniters and this rating is important for you to match up correctly with your current igniter OHM rating or you could damage the gas control valve and/or the new igniter.
Posted on May 12, 2010
SOURCE: Won't start
Starting problems with 2-cycle engines are usually traced to fuel line/filter clogging due to jelling of the fuel mixture while the engine is idle. Best fix is fuel mix pretreatment with some kind of gas saver in the gas can. Marine grade additives are the best, such as 2+4 gas treatment. Now your stuck with pulling the fuel lines and blowing them clean. If the carb has a primer bulb, you can sometimes force the fuel through, but a complete cleaning is in order. Pulling the plug and putting a few drops of fuel mix directly into the cylinder head, (or in the air intake), can sometimes get the motor to fire. This proofs the problem as being fuel starvation.
Posted on Jun 05, 2010
  • 19 Answers
SOURCE: Poulan Pro riding mower 300ex Steering
Sounds like a very loose connection or broken steering component,front wheel bearings?
Posted on Jul 05, 2011
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
My poulan pro 42cc is hard to start ,,, its1 year old an i'm not sure if its worn out from alot of use or if its with the ignition
throw it out and buy a new one this is a throw away scoiety we live in due to cheap *** chinese **** oh yeah go green
May 27, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need replacement wheels for selfpropelled (front)power pro
You can go to searspartsdirect.com and enter your model number. Your mower is made by the same factory that makes the Craftsman mower so they should have it listed and you can order the wheels from them.
Jun 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
