Question about Cameras
Transferred photos from computer to sound card but it shows no images
  • Cameras Master
  • 5,412 Answers
Are you sure you have stated the issue correctly ? I know of no way of transferring any data to a sound card.
Posted on Aug 13, 2017
  • 1257 Answers
SOURCE: Pentax Optio A20 in playback
I think you need to create some specific folder in SD card then copy paste your images in that folder,
first take few pictures from CAM and then see which folder has been created by the camera
did you check any other SC card?
Posted on May 28, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
  • 5568 Answers
SOURCE: photos being transferred to computer lost connection during transfer. Now no photos show in the queue
A good reason to use the 'copy' function whle transferring. Doing this will preserve the pix in the camera memory until you are sure they actually arrived on your computer.
If you have a card drive, you might pull your memory card and plug it in directly to see what might remain there. It may come up as only a 'removable drive' that you can address as if it was any other.
Posted on Apr 19, 2009
  • 62 Answers
SOURCE: Can photos be transferred from internal memory to sd card
im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
Posted on May 01, 2009
SOURCE: photo from computer won't show on camera
I suspect the JPG is NOT the correct size and resolution, it has to be a certain "way" to be used by the camera. You need to consult your manual and find out the exact size etc.
Posted on Mar 22, 2010
Transfering images to computer/ failure
Check to make sure your images are on the card, and not stored in any local camera memory. If the computer does not recognize the SD card (if used) and asks to format it, then try another computer to see if it can read the card. Finally, if the camera uses a cable, make sure the computer recognizes the camera when plugged in. When the camera is recognized, you should be able to directly view and download images from the camera. Make sure you note where the images are stored on the computer.
Mar 16, 2015 | Computers & Internet
My D3000 focuses, but only black images show up on the memory card. It's as if the images are not being transferred to the memory card
Dropping a D3000 is one to make you you say something bad
Outside of trying different lenses and memory cards, there\'s probably little anyone can tell you that you\'re going to like to hear. If it\'s a problem inside the camera, it should go back to Nikon for repairs. If you obtain an RMA from Nikon and send it in, they will evaluate it and give you a repair price. At that point you can decide whether or not to go through with repairs or cut your losses and buy a replacement.
Jan 31, 2013 | Nikon D3000 Digital Camera
EOS utility not tranfering all images on card
You are better off to simply remove the card and either use your built in card reader or obtain a external USB card reader and transfer your images that way. All you have to do is open 2 "My Computer" windows. Simply drag your photos from your card to your C: drive.
Dec 06, 2012 | Canon EOS 40D Digital SLR Camera Digital...
Camera says "communication error" when trying to transfer images to computer. Why?
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 10, 2012 | Canon G12 Digital Camera
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
How to upload photo
Transferring images from a Memory Card to a Windows Computer Follow the steps below to transfer images from a memory card to a computer running Windows. Step one: Insert the memory card Follow the steps below to insert the memory card into the HP All-in-One.
  1. Turn the memory card so that the label faces left, and the contacts are facing your HP All-in-One.
  2. Insert the memory card into the appropriate slot on the HP All-in-One.
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass-storage port on your HP All-in-One. These read-only partitions are added by the drive manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive. When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading... appears on the color graphics display. The status light next to the memory card slots blinks green when the card is being accessed. If a memory card is inserted incorrectly, the status light next to the memory card slots blinks amber and the color graphics display shows an error message such as Card is in backwards or Card is not fully inserted. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. Safely remove a card only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software After inserting the memory card into the HP All-in-One, the memory card appears as a drive on the computer. Follow the steps below to transfer the images on the memory card to the computer.
  1. Press the Photo button to display the Photo menu.
  2. Press the down arrow button (c01133817.jpg ) to select Transfer to computer .
  3. Follow the prompts on the computer to complete the transfer of images.
    NOTE: If there are photo files on the memory card that have never been transferred before, a dialog box on the computer asks whether you want to save the photo files to the computer. Click the Transfer option and all the new photos from the memory card are saved to the computer.By default, the image files are saved in month and year folders depending on when the photos were taken. The folders are created under the C:\Documents and Settings\username\My Documents\My Pictures folder.
Dec 08, 2010 | HP Photosmart 3210 Printer
Photos being transferred to computer lost connection during transfer. Now no photos show in the queue
Apr 19, 2009 | Nikon COOLPIX L18 Digital Camera
Settings for date and time on the camera
By default Olympus cameras do not print or show the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
However the computer will only show the date information as part of the photo properties.
Jan 07, 2009 | Olympus Camedia C-450 Zoom Digital Camera
Photos transferred to computer and memory card emptied but when card put back in camera it says it is still full. When in review it the card has no images on it. There is a folder icon on the camera...
  • hi just put ur camera again with memory card in it and attach it with pc then if u have photos on pc jst format ur memory card from pc and again de-atatch ur camera then see results
Sep 14, 2008 | Canon Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
