Question about GE Dehumidifiers
When the compressor does not kick in and the fan is working and the unit is only a year old...is there a fuse or something for the compresser?
    President:
  • 2,559 Answers
Start/run capacitor is bad or unit has a leak.
Posted on Jul 27, 2009
My Kenmore dehumidifier fan runs all the time & compressor kicks in & out. I the fan supposed to run continually.
yes if its less than two years old the new ones run the fan all the time and cycle the compressor off humidity of room , the fans even have speeds on some models so you can turn em down
Nov 08, 2014 | Dehumidifiers
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
Jun 26, 2011 | LG LD65EL Dehumidifier
I have a GE AHH50LMG1 dehumidifier. It is less than 2 years old. When I turn it on, it displays 20% RH. The fan runs but the compressor does not kick in. I assume that is because it thinks the humidity...
It could be just the sensor, but not likely... many times it is the circuit board that goes bad, making the repair almost prohibitive.. as the circuit board, if you can find one, is often half or more the cost of a new unit...
But you are correct... if the unit thinks the humidity is 20% then it will not bring on the compressor...that is what is happening...
heatman101
Jun 25, 2011 | Haier HD656E Dehumidifier
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
4 year old dehumidifier does not extract water
It may have lost its charge of refrigerant. Check the warranty for sealed system, or if it is just the compressor which is covered. There are coils above the bucket area. Check for possible frost on only part of the coil. It is a sign that it has a leak at some point and has lost its refrigerant charge. If it lost all the gas there will be no frost nor condensation on the coils. Four years old and $75 bucks, its your choice.
Jun 03, 2008 | Dehumidifiers
Blown Fuse on Compressor of Dehumidifier
That part is a thermal protector. If you can't find it at Radio Shack they should be able to direct you to an appropriate electronics store.
May 19, 2008 | Maytag M3DH30B2A Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Dehumidifiers Logo
220 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
