Question about Haier Heating & Cooling
Haier hpy12xcn portable air conditioner keeps shutting off when the cooling tries to turn on.
I have drained it completely and cleaned it inside and out. It works fine in FAN mode, but when I turn it on COOLING mode it shuts off when I change the temperature to 72 and the compressor tries to come on. I purchased the original one in 2013 and they had to replace that one with a new one in 2014. Now it is 2017 and this one no longer cools. Is this the normal life span for these Haier units?!?
oscarn
  • 110 Answers
SOURCE: cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Posted on Sep 07, 2007
  • 86 Answers
SOURCE: Not cooling
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Posted on Mar 17, 2008
SOURCE: air conditioner
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
Posted on Sep 24, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
I have a portable air conditioner that has started beeping and shutting off. Then I drain it and turn it back on. It lasts maybe an hour and then I have to do the same thing again.
Helen, your air conditioner should drain by itself. Your a/c should
tilt slightly to the outside of the house but not tilt to the inside. Check your drain and your drain tube and make sure they are open.
Jul 18, 2017 | Heating & Cooling
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Haier beep will not turn on
Your unit may be shutting off because it is full of water. If you haven't yet try draining it and then check again to see if it operates.
Jul 10, 2012 | Haier CPN12XH9 Portable Air Conditioner
No cool air coming out of unit...tried cleaning filter
REMOVE THE PLUG AND DRAIN THE UNIT IF THERE IS TOO MUCH CONDESATE (WATER) THIS UNIT DOES NOT COOL.
BEST OF LUCK.
Jun 02, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Leaking water
Very common problem with these systems. This depends on humidity in the air. Some systems have a setting that you can turn off the dehumidifier. The downside to this is it doesn't cool quite as well as humididty absords heat. The drain pan in your system is probably overflowing. You have a couple options, you could "hard drain" it to outdoors, empty the drainpan regulary, or change the air settings (this may not solve completely if you live in a humid area).
Aug 30, 2009 | Haier HPM09XC5 Portable Air Conditioner
Haier hwr05xc7 after a few hours completely shuts off
I don't own this unit. However, you can try calling the "Haier Customer Satisfaction Center" @ 1-877-337-3639. Good Luck! littlesinger
Jul 21, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
