Question about Juki Sewing Machines
I have a juki hzl e50. I replaced the bulb and 20 minutes later the bulb blew, machine stopped and won't turn on again. Help?
  • 87 Answers
SOURCE: machine just stops but power is on
that is the power board (in base plate) you need a rebuilt base plate. Unless you can rebuild the power board. You can buy a rebuilt board and send your in and receive a core credit. It still will probably run $200 to get one. It will also come with a 2 year warranty.
Posted on Mar 18, 2009
  • 8 Answers
SOURCE: buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Posted on May 30, 2009
  • 3 Answers
SOURCE: double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Posted on Jun 16, 2009
  • 47 Answers
SOURCE: Manual Guide for Juki Frou Frou HZL-11
Visit us at
Posted on Jul 24, 2009
  • 59 Answers
SOURCE: i need to know how and where to oil my juki
your machine is not a self oiling machine, you should put the oil on the needle bar, and to the bobbin.
Posted on Mar 26, 2010
Juki hzl_e61sewing machine
Sounds like a safety feature, ie is it getting too hot? May take it for service.
Oct 10, 2016 | Juki HZL-E61 Computerized Sewing Machine
Why is it seizing up and clocking after doing basic sewing?
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
$749.00 - ‎In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
Dec 01, 2015 | Juki HZLF300 Sewing Machine
User Manual
APW-231,232,235,236,239,240 ENGINEER MANUAL.pdf, File, 3.07 MB. APW-297&298EM01_e. ... .pdf, File, 1.08 MB. DMN-530-4 Instruction Manual (No.02) BE5304S0B0A.pdf, File, 777 KB ... DP-2100 EM00_e.doc, File, 67.8 KB. DP-2100
[PDF]HZL-F series - JUKI
any other user servicing adjustments mentioned in the instruction manual. 11. ... can be used on sewing machine model HZL-F300, HZL-F400, or HZL-600.
Oct 27, 2015 | Juki Sewing Machines
User manual of juki hzl-7700
Is this a home machine? There are many of the manuals online at
I didn't see this model #. They have one for an HZL-272 that might be similar
Jul 02, 2015 | Juki Sewing Machines
Where can i get a user manual for MISIN HZL 7000
Here is a list of all the Juki manuals that are available; I don't see a HZL-7000/
JUKI Sewing Machine manuals
Feb 14, 2015 | Sewing Machines
Stop start button is not turning green when I put the foot down
Is the foot correctly attached? Is the machine clean? Bobbin winder on or off? Try turning it off again crisply.
Feb 25, 2014 | Juki Hzl-K85 Computerized Sewing Machine
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Where can I find an instruction manual for a Juki nz120
Ask your local Juki Dealer....
Juki does have a few they've released for old machines but yours doesn't appear to be there. Are you sure it's NZ120 and not HZL 20?
Aug 10, 2012 | Juki Sewing Machines
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
