Question about Garden
Why does the motor quit when you engage the clutch with out the deck on the tractor JD l 120 automatic
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 273 Answers
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
Posted on Aug 12, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
Why can't I engage the mower deck?
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
www.youtube.com/watch?v=wH9tZl6GzE0
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Tractor quits when engaging the blades
unhook your clutch and see what happens could be bad clutch
Jun 01, 2013 | Mtd Garden
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
How to replace electro mag clucth on JD Gt242
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
Sep 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades will not ingage
your electric pto clutch switch is bad replace it
Nov 14, 2008 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
