Question about Refrigerators
How to use detergent dipenser - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 45,112 Answers
Refrigerators do not have detergent dispensers.
Posted on Aug 13, 2017
LEAKING SMALL AMOUNT OF WATER UNDER FRONT LEFT CORNER OF WASHER. LEAKS WHENEVER WATER GOES INTO THE DETERGENT DIPENSER.WHAT IS THE CAUSE?
Get a level and check the level of the machine. The front should be slightly higher than the back and even left to right.
Jun 02, 2015 | Maytag MVWB850YW Bravos XL HE Top Load...
My pressure washer does not dispense the detergent
they will only pull soap when using the large black tip or no tip at all
Jun 20, 2012 | Garden
When it drains the water smells like sewage
1 cup of bleach w/ no clothes place in detergent dipenser every 2- 4 weeks will kill the bacteria let it run the entire cycle to end.
Apr 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Detergent still there after cycle
more than likey you have stripped boith the pump and emacorator
so your not getting any real water pressure, so the spray arms are not spinning, thus washing the soap from the dispensor and into the cycle.
take the thre t-20 screws off the wash cowel, top of the motor area, below that you will find the pump head, on small t-15/20
around the pump head you will see 6 t-20
once removed you can lift the pump out of the way
below that you will see the emacorator and motor seal
the parts you need are number 9
inspect the shaft you will see threads thats for the pump shaft to screw down onot the motor shaft
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170522&diagram_id=1332320#d1332320
Oct 26, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Automatic ice maker will not dipense ice cubes.
This may be a circuit board problem for which there might be a recall from GE. I had the same problem and found information about it on the web site below.
http://applianceguru.com/view_topic.php?id=13243&forum_id=1
Feb 19, 2009 | GE Profile PSS26NGS Side by Side...
Fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Apr 09, 2008 | Dishwashers
Water/ice dipenser
Sorry, these become dirty after a period of time. Try spraying up with soap and water, clean as best you can, let dry. And then spray with a canned lubricant. Silicone type, (as opposed to WD-40 type) may work best. But OK to try either.
Feb 07, 2008 | Maytag MZD2766GES Side by Side...
Kenmore HE3 Front Load Washer
Remove the dipenser and feel down inside the hole. You will probably feel a detergent build up in the cavity. If so clean this out and rinse with hot water. This problem is becoming more common since people are washing more in cold water to save electricty. Some detergents and fabric softeners will not disolve in cold and it "gums" up the works. Post back to let me know what you find.
Oct 08, 2007 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
