Question about GE Refrigerators
Our GE Profile frig won't go into auto defrost mode
Every 3 weeks or so it builds up frost in freezer and gets warmer, until it's not cooling. I have turned off cooling at control panel and manually defrosted it several times, but sick of doing that. Not sure if it's a circuit or coil, but is there an easy way to fix this?
  • 3 Answers
It is normal to build up frost at the Evaporator.
The Automatic-defrost-System removes the Ice 3 or 4 times, every 24 hours.(de-frosting).
1 The Fan MUST rotate , inside.
Is the Fan blowing Air inside,??
sometimes The door must be shut, then the fan-motor starts (,put your ear against the door when you close it and listen for the fan- noise,)
There may be an Automatic-Defrost fault:
Faulty :
Defrost-Timer, (electro-mecanical) ( DT ) c. fault.
Defrost-Heater,. ( DH ) common fault.
Defrost-Termination-Timer,. ( DTT)
(Over) Temperature-Fuse. ( TF )
If the Refrigerator has 'Electronic' controls,
a Computer controls the Automatic Defrosting.
A Temperature-Sensor replaces the DDT.
A Computer-controlled timer replaces the DT
----- A Sensor faulty?
-----Control Board (Computer) faulty. Common fault.
I found,-
To read and remember is easy.
To 'understand' takes a little more time .
To practice, improves my skill,
With skills, it is easy to perform the task.
Experience has build up my skill & confidence.
Wisdom is, when I admit that I require additional knowledge.
(Happiness is a result of sharing and caring.
That's why I am happy.)
K.
Posted on Aug 13, 2017
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold air around in the freezer and blow the cold air from the freezer into the fresh food section, it also sucks the warm air from the fresh food section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
00082692.jpgEvaporator fan motor
Posted on Jan 21, 2009
heatman101
  • 43501 Answers
SOURCE: I have a whirlpool 21'
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 28, 2011
Our top mount Kenmore fridge (Model # 253.77872509) is frosting up in the freezer section. Have turned off & defrosted the freezer on several occasions - it works for a few weeks but then begins...
Normally when frost build up occurs it's because warmer outside air is getting into the freezer and the moisture from that warm air cools and condensates then freezes into frost or ice. You either have a bad seal like the other listing states try leveling the front a little higher than the back. Or you may have an issue with the defrost heater, thermostat or timer. Do you have a light that comes on from time to time? If so you have an auto defrost unit. If there is no light you may not have a frost free freezer which means you will have to remove the frost manually.
Please check the bellow links for your knowledge:-
http://www.wikihow.com/Stop-Your-Fridge-from-Ice-Build-up
http://www.ehow.com/how_4781069_prevent-frost-build-up-freezer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
GE Fridge not cooling
is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Nov 07, 2008 | GE Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Confused /
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
