Question about Makita Drills
Is it the chuck or the clutch?
Makita LXFD01Z 18V LXT Lithium-Ion Cordless 1/2" Driver-Drill Chuck just slips when I try to loosen it.
  • 23 Answers
Problem with clutch
Posted on Sep 30, 2017
  • 18 Answers
SOURCE: keyless chuck
You will find a screw inside the chuck that needs to come out first of all but beware that it will be a reverse thread. This is to stop it loosening whilst in use. then you will need to unscrew the chuck but it isn't easy as you have to hold the shaft that the chuck is attatched to. You can sometimes take the chuck off by holding it and pulling the trigger while in reverse. (but they can be stuck fast).
Posted on Sep 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
Posted on Dec 20, 2008
SOURCE: 18v makita bhp451 cordless hammer drill.clutch
its prob stuck between gears one and two try a little wd40 on the gear selector switch
Posted on Jul 31, 2009
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Posted on Dec 15, 2009
Chuck/shaft wobble
check the bearings for the chuck shaft as they may be worn out
Aug 03, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
How to remove chuck on makita bdf452
the chuck should open all the way then look down the old one attached to the drill there should be a screw near the end undo the screw and then it should come off :)
Mar 23, 2010 | Makita BDF452HW Factory Reconditioned 18V...
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Feb 12, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Keyless chuck
Aug 10, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Chuck change
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Feb 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
268 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
