Question about Suzuki Boating
We have an old not sure how old suzuki 14 hp outboard which does not have a kill cord . Can we retro fit ? Thanks
    Sergeant:
  • 320 Answers
Symply replace the actual engine stop switch with a kill cord type.
Every Suzuki model should fit...
Posted on Sep 25, 2017
4 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: Retro fit ABS brakes to 2008 Suzuki M50
There are no aftermarket ABS kits available. Due to liability issues I would not expect to see them in the US. It is theoretically possible to adapt an ABS system from another vehicle for use on the bike but the work involved would be prohibitively expensive. The best improvements you can make are:
1) Working on your braking technique.
2) Using aftermarket brake rotors such as Galfer Wave units.
3) Adapting braking systems from another bike that has great brakes (GSXR or similar racing style bike).
4) Making sure your current system is operating properly (good fluid, good pads, pads moving in the caliper as they should).
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: about 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Posted on Mar 13, 2010
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
Suzuki
https://www.tradebit.com/filedetail.php/142965517-suzuki-outboard-service-manual-df90-100-115
May 02, 2016 | Boating
Why will my 1997 evinrude 18hp boat not start
could be any number of things . is the kill cord in place , do you have spark , is it getting fuel to carb ,
Sep 04, 2015 | Clymer EvinrudeJohnson Outboard Shop...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
How i thread my pull cord on my 6.0 HP outboard evinrude
How old? If it is the old system that looks like a spiral ramp, very carefully. I knot one end, feed it into the hole at the top and then feed it around without taking apart the starter. The spring is a pain to work with.
May 18, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
No spark
stop switch is on the control box near helm or on the dashboard where you fit your safety lanyard to kill engine wen you fall over ! you also have an ingear safety switch in the control box !
May 26, 2013 | Seloc Mercury Outboard Engine Repair...
Suzuki outboard motor 65 hp --oil sensor keeps
Jun 19, 2010 | Boating
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Boating Logo
Top Suzuki Boating Experts
Steve
Steve
_-__-___-_
_-__-___-_
JonSnell Electronic
JonSnell Electronic
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
