Question about Shark Vacuums
I am trying to figure out how much water to put in a shark 2 and 1 vacsteam
Having problem with steam not coming out to do floors
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having problems with your Shark Steam Vac. One solution you can try is to create a solution of approximately 50% water and 50% CLR (calcium, lime, and rust).
Put the solution into the water tank of your vacuum and let it sit for awhile. Over time your vacuum may have developed a build-up of calcium which is blocking the pores that release the steam. This solution should break-down the calcium and allow steam to flow out of the vacuum.
If you do not have CLR on-hand, an alternative found in most kitchens that can be used is vinegar. Again, make a solution of vinegar and water and allow it time to sit in the tank attached to the vacuum. Then try running the machine.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 06, 2015 | Shark Rotator Vac-or-steam 2-in-1 Hepa...
TAKE APART A SHARK 3601
My shark 3601 died on me. A replacement is on its way but I still wanted to take a peek inside. After trying to get it open for about two hours, I figured it out. You have to remove the small screws by where the handle goes in. Then you can work your way inside. I removed all if the obvious screws to my frustration. I probably won't be able to put it back together again but I sure know how to take it apart. By the way, shark is sending me a replacement one for forty bucks.
Feb 21, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I HAVE A NEW SHARK STEAM CLEANER - PURPLE - I PUT ABOUT 1/2 CONTAINER OF WATER - PLUGGED IT IN AND NO STEAM??? WHAT AM I DOING WRONG THE BLUE LIGHT SHARK IS LIT UP
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Feb 01, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not syeam grey pruple shark steam mop
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heater does not generate steam / water temperature not hot enough shark S3202 has only been user 10 to 15 times. can a new heating element be installed? where can I buy element?
The element is not sold anywhere... go figure...
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark mop is emitting steam every where but where its suppose to. could it be clogged,i put water in it, after 2 minutes it made a popping sound.
heatman101
Sep 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have the shark steam mop which uses water only but i would like to try putting some white vinegar in with the water for cleaning purposes, will this hurt the steam mop at all?
no, it will not hurt it..
heatman101
Aug 18, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not release water or steam.
heatman101
aa
Feb 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
Top Shark Vacuums Experts
JoyEd Stevenson
JoyEd Stevenson
Danny Kuhlmann
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
