Question about Crown Office Equipment & Supplies
1992 crown vic the trip odometer and the odometer not working
How to fix?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
If the speedometer works but the odometer does not, the issue is in the speedo head itself and likely the odometer drive gear is stripped.
Posted on Aug 12, 2017
  • 979 Answers
SOURCE: 1994 crown vic speedometer works
Have that entire assembly rebuilt and be done with it. Those are a major pain if you've never done one before, and I speak form experience. PS The "clear tab" lever could be stuck or broken...accordianman
Posted on Jul 22, 2008
  • 1214 Answers
SOURCE: 1992 Crown Vic wont crank
Check the starter solenoid. Usually mounted on a fender well. Find by following the + battery cable.
Posted on Feb 14, 2009
  • 508 Answers
SOURCE: 1990 Crown Vic LX Odometer does not work
I think the speedo head is probably good. You need to check the speedo cable and the gear at the end of the cable housing. If the gear is cupped in the center it is worn out. Replace the gear by the color code at your local Ford dealer. The other scenario would be that the gear on the output shaft is worn also. This would require the tailshaft be removed from the tranny and the nylon gear replaced on the output shaft. Good luck.
Posted on Mar 12, 2009
  • 12 Answers
SOURCE: odometer indicator not working for
OdometerGears.com has the gears for you to repair the odometer. If the odometer and the tripometer are stacked you will need and E20= 20 tooth gear and a 16 tooth medium pod. If the odometer and tripometer are split left to right you will need 2 drive and 2 worm gears. Give them a call and they will offer you a discount for the four gears. The total for two gears is $54.00 and for the four gears is $89.00 both prices include the shipping.
Posted on May 29, 2009
  • 12 Answers
SOURCE: I have a 1992 lincoln towncar and the odometer doesn't work
If the speedometer itself is currently working fine, it may be that the Odometer and Trip-o-meter gears are broken. Lincolns OnLine have a large database of information regarding Town Cars from all years. This specific link will help you to order and replace the proper gears for your car.
http://www.lincolnsonline.com/tech/00202.html
Posted on May 26, 2010
How big is the gas tank on a 1992 ford crown vic. how many miles to the gallon. my gas gauge doesnt work. so i dont know anything about the gas.
1992 Ford Crown Vic 4.6 L V8 Automatic
Fuel tank capacity is 20 gallons (US).
Your fuel consumption will be affected by many factors, such as :
- how you drive the vehicle
- the condition and tune of the motor
- driving conditions (traffic, city use, highway use etc)
- tire pressures
- type and grade of fuel used .
It is impossible for me to estimate what fuel consumption you can expect from your own particular car without a whole lot of information.
It's unwise to run the vehicle for long with no working fuel gauge.
Dec 17, 2010 | 1992 Ford Crown Victoria
92 crown vic - temperature guage on the dash is not working...
The temperature gauge sending unit is located in the front section of the intake manifold, just to the right of the alternator on the 4.6L engines. Got this from autozones repair manuals
Mar 16, 2010 | 1992 Ford Crown Victoria
Stuck odometer - how do I fix- speedometer works fine and cruise control too.
Since everything else is still working, your odometer just crapped out. This is very common on the Vics/ Marquis that utilize the mechanical style odometer. I've had two of them (1989 and 1991 Grand Marquis) where the odometer failed. You will need to remove the odometer from the instrument cluster and either replace it with a new unit (good luck with that) or send it out to be repaired. There's a guy that does this specific type of repair, search the Internets and you'll find him.
Side note: Since it was only the main and not trip odometer that failed on my two Panthers, I learned my lesson the second time around and just kept track of my mileage using my trip odometer and a pen and paper in the glove box. A lot easier than tearing the dash apart at the time. If it happened now on my current car ('94 Vic LX), I would fix it. It's not a really hard repair if you know what you're doing or can find someone who does to give you a hand.
Jan 04, 2010 | 1994 Ford Crown Victoria
Odometer stuck speedometer works ok 1992 mercury grand marquis
The only fix is to replace the speedo head. I had a 92 crown vic (same as marquis) and the speeometer shop could not repair it. So, i had to replace it. They give you a sticker to write the present mileage down for reference,and afix it to the drivers door jam.
Oct 07, 2009 | 1992 Mercury Grand Marquis
1992 crown vic with 78K miles. Started skipping
Replace you Maf sensor and have a nice day. lol does the hesitation go away when you let off the gas. does it buck hesitate and misfire under load? most common problem is the maf sesnor.
easy to change. don't buy a used part it may develop the same problem after a little while. you can try cleaning the wire inside with brake cleaner (not intake cleaner). it may or may not help.
Jun 26, 2009 | 1992 Ford Crown Victoria
Mar 12, 2009 | 1990 Ford LTD Crown Victoria
Feb 14, 2009 | 1992 Ford Crown Victoria
Odometer indicator not working for buick century custom 2001 about 1 week ago, in the middle of a trip, my odometer stopped reading miles. the push button where u can reset your trip miles is not counting...
Oct 02, 2008 | 1994 Ford Crown Victoria
1992 crown vic 4.6l
did you check the inertia switch?? that's what happened to mine
Jul 25, 2008 | 1992 Ford Crown Victoria
Top Crown Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Crown Office Equipment and Supply Expert? Answer questions, earn points and help others
