Question about Garden
Was cutting grass today. Jumped a belt. But the belt back on and the mower does not move . I have a ss5000 zero turn
  • Clyde Ottaway Aug 13, 2017
    the belt is streched or the tenson spring is off or broken
  • 109 Answers
SOURCE: blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Posted on Apr 24, 2009
  • 85 Answers
SOURCE: riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Posted on Sep 23, 2009
SOURCE: I have a husqvarna ez4824 zero turn lawn mower.
either a weak seat switch or your electric clutch is going bad!
Posted on Jul 06, 2010
Testimonial: "Thank you very much for your input. You were right - it was the clutch."
  • 128 Answers
SOURCE: I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Posted on Aug 09, 2012
kdh1961
  • 312 Answers
SOURCE: My drive belt fell off. I put on a new one and the mower stalls out when I mow thicker grass
drive belt to tight
Posted on Aug 18, 2012
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Was cutting grass and mower just quit pulling
sounds like the drive belt broke you need a new belt
Jan 29, 2013 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
If the belt comes off a riding lawn mower...will it still cut grass
Probably not.
I would expect to find two belts on a riding mower; one to drive the riding lawn mower (lets call this the DRIVER) and one to drive the actual mower part (lets call this the MOWER).
To answer your question one way, if the driver belt is off, it will still cut grass, but you cant move the mower. If the mower belt is off, it will move but not cut the grass.
If your belt is broken, take it to an automotive parts store or garden equipment place for replacement. You might also support a FixYa.com advertiser.
I hope this answers your question. Thanks for posting at FixYa.com and please vote.
thanks
a
Nov 14, 2009 | Garden
How do you tighten PTO belt?
If the belt is loose it probably needs replaced or has jumped out of one of the pulley or belt guards allowing it to be sloppy. Belts get stretched in many different ways, tall grass, grass getting in the pulley, or they just plain stretch. First though, check to be sure the belt hasn't jumped out of it's normal runway.
Jun 23, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
