Question about Power Up Computers & Internet
Sound bar on sharp ht-sb300 power up icon continue to go in circle and will not power fully on
3 Suggested Answers
gopakumarg43
  • 74858 Answers
SOURCE: i have a sharp aquos
Hello
What is the probelm do you face with your Sharp HT-SP300. Give me some more details by Fixya please. OK.
Posted on Mar 11, 2011
  • 5263 Answers
SOURCE: Hi.How can I connect SHARP HT-SB400 sound bar
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Posted on Mar 05, 2012
Battery icon sign with circle check indicate what?
Replace Lollipop battery indicator with circle battery icon ...
https://www.reddit.com/.../replace_lollipop_battery_indicator_with...
RedditDec 21, 2014 - They just put another battery icon on notification bar. It looks kind of... ... Log in or sign up in seconds.'. English. limit my search to /r/Nexus5 ... Replace Lollipop battery indicator with circle battery icon? (self.Nexus5). submitted
Nov 25, 2015 | Cell Phones
Sorry i am french, can not get sound from my sound bar sharp connected to my LG tv I think i dont know how to connect it all together... That´s mean the receiver, play station, blue ray sharp and the Sub ?...
I'm no good at French, but perhaps you manage anyway.
I used this on Google "sharp HT-SL70 manual" because I don't know the French word for manual. I did find manuals form Sharp in different languages, but not in French. So perhaps you try this yourself. Don't open the first links, where it says manuals on line, because they want to install malware. Only open the Sharp links where you already see PDF in front.
Jan 13, 2015 | Sharp Home Theater Sound Bar
I am not getting any sound from my sharp sound bar
if your not getting sound either A you dont have power to it, B, the Wires arent hooked up correctly, C the Speaker Sound Bar is Toast. BUt i would take my chances that its A and B. Check your wires and make sure you have them hooked up correctly.
Nov 16, 2014 | Sharp HT-SB40 2.1 Speaker System - 310 W...
What remote can be used to control a HT-SL75 sharp
Features
Other than the cool things you can do when setting up the Sharp HT-SL75 system, there are no features to really play around with. This means no screen, no extra options to tinker, no virtual surround sound, no Wi-Fi and no Bluetooth. It is meant to be connected to the TV and it just works from there. No remote control is included either since you can simply use the TV remote control to adjust the volume.
Sep 25, 2014 | Televison & Video
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
I cannot get sound when connect sharp sound Bar HT-SL50 to a Sharp LC60LE835U
You have to go into the sound setup menu and select which audio out you are using. Select either digital or fiber so the TV can direst the sound to the proper port.
Jul 08, 2014 | Sharp LC60LE835U 3D LCD TV
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have just purchased a sharp HT-SB250 sound bar to go with my sharp 32" Aquos LED tv. The item came supplied with the RCA cable and having connected it to the sound bar and the audio connections in...
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
Jul 26, 2017 | Audio Players & Recorders
The sound symbol has a red circle x on it and i can't hear any sound
Left click on the icon. volume bar will appear vertically above the icon. Below the volume scale is another icon that looks like the one one on the task bar. Left click it once and it will un mute the sound.
Jan 10, 2011 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
