Question about Kitchen Ranges
Gaffers & Sattler with broken door springs and need a diagram.
I have an Qccidental RH 34 Gaffers & Sattler with broken door springs and need a diagram. And where to get parts.
2 Suggested Answers
  • 125 Answers
SOURCE: Gaffers & Sattler stove
The pilot is under the bottom oven deck, usually you can lift the front edge, and slide it out, smelling gas without a pilot would be bad, that means either A : your safety is bad, and allowing gas to flow anyway, which requires replacement, and you may as well replace the thermocouple, and clean the pilot. or B : it is old enough it does not have a protected pilot, and you have to manually light it, usually indicated by an open hole in the front middle of the oven deck plate when you open the door, with a tube going to the burner. or C : your oven burner is bad or misaligned with the burner, and is shooting gas away from the pilot area, it would light via an open pilot eventually, but you don't want that. Please let us know, or have a qualified servicer look at it. Happy New Year, and thank you.
Posted on Dec 31, 2008
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
Mar 01, 2017 | Heating & Cooling
Gaffers and sattler parts
go to qppliqnceparts.com and I think you can order it there
May 22, 2014 | Kitchen Appliances - Others
Gaffers & Sattler stovetop model 1465/944. The burner mechanism malfunctioned when we turned the knob where it connects to the burner and is leaking gas and will not turn off. We would like to find...
Not that many parts for a 33 year old appliance are still avaiable but try one of these places
http://www.antiqueappliances.com/
http://ths.gardenweb.com/forums/load/antiques/msg0717405813237.html
http://www.facebook.com/pages/Vintage-appliance-restoration/124642017603277
http://www.stovelady.com/
I have been a appliance tech for 30 years and love the vintage appliances and strive to search for to repair them whenever possible if the customer wants to hold on to them
Good luck,
Gene
Aug 05, 2011 | Cooktops
I lost my manual for 97 mountaneer fusebox diagram
1. pwr antenna 7.5 amp 2. high mount stop lamp 7.5amp 3. lights 15 amp 4. left headlight 10 amps 5. data link connector 10 amps 6. airbag, blower motor relay 7.5 amps 7. lamp dimmer 7.5 amps 8. RH headlight, daytime running lts, fogs 10amps 9. autolamps, memory seat 10amps 10. blend door ( heater), shift lock actuator, cruise control, brake press limit, console, integrated contol panel, rear blower relay 7.5amp 11. radio, dimmer relay, inst cluster, autolamps 2 7.5 amp 12. liftgate wiper washer, front washer relay 10amps 13. brake on off switch 15 amps 14. antilock brakes 10amps 15. airbag diagnostic 7.5 amps 16. wiper main 30amps 17. cig lighter 25 amps 18. heater-a/c eatc module 15 amps 19. radio noise cap, ign coil, PCM power diode 25 amps 20. radio, powr ant 7.5 amps 21. turn /hazards 15 amps 22. turn hazards 10 amps 23. rear wiper relay, 10 amps 24. anti theft 10 amps 25. cluster 7.5 amps 26. rear window defrost, overdrive trans, backup lamps 10 amps 27. interior lighting 10 amps 28. GEM, mem seat 2 , 7.5 amp 29. radio CD changer 10amps 30. not used 31. rear blower relay, RH heated mirror, 7.5 amp 32. heated rear window switch RH heated mirror 7.5 amp 33. DRL module, RH LH daytime running lamp 15 amp 34. power antenna module, remote chassis unit 7.5 35. not used 36. not used
Jan 07, 2010 | 1997 Mercury Mountaineer
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Have a Gaffers and Sattler furnace mod # 85 FDF ser # PV 09020. Pilot is lit, when I call for heat nothing happens. T-stat is okay, thermo couple okay/new. Fan will run when manually turned on at unit with...
When it call for heat you need a voltmeter to see if you have voltage at your gas valve. Check that first. You could jumper your stat between w and r to see if you have a bad stat. Rus
Nov 28, 2009 | Heating & Cooling
Stove-top burner grate is broken
I THINK NO AVAILABLE FOR REPLACE COZ IS FACEOUT MODEL AFTER 10YRS.ALSO U CANNOT REPAIR COZ EVERY TINE U USE WILL BROKEN AGAIN.
May 26, 2009 | Cooktops
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
