Question about Cell Phones
My screen light shuts down after about ten seconds even with the sleep button set to five minutes
SOURCE: Unit shut down after five minutes
Take the back of the TV coved off. About 12 Phillips screws. Then use a can of compressed air and clean all the dust out. You'll be shocked at how much dust there will be. Use a vacuum to suck the flying dust. Be careful not to bump anything with the vacuum hose. Robert
Posted on Aug 07, 2007
  • 395 Answers
SOURCE: TV just turns itself off
does this happen at night or dark days when lights are on? if so you might be using CFL lights which interer with IR info to the set. it can cause other problems such as random cannel change or no remote responce.
Posted on Jan 17, 2008
SOURCE: will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Posted on Jan 21, 2009
SOURCE: shuts down after about five minutes and wonr
If it runs really rough before shutting down it is most likely a spark plug.
Posted on Aug 09, 2009
greg_margo
  • 1959 Answers
SOURCE: Sleep mode will not disable, even when send button
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Posted on Aug 11, 2009
Response to page turn command very, very slow, Also omits text at times.
You might want to try a reboot. This means when it's on, pressing and holding the power button for about ten seconds until it shuts off and shows a blank screen and about five seconds thereafter just to be sure. Do this when on the home screen. Then press the power button once and wait until the Kindle tree appears and a progress bar shows. It'll take a minute or so for the progress bar to go all the way across then it will boot up into the PIN or home screen depending. I would recommend using a PIN as if you ever lost it anybody can use your account to buy books.
Pressing the power button one short time only puts it to sleep so every so often, if it becomes balky, doing a reboot clears and speeds it back up.
Mar 27, 2015 | Amazon Kindle Paperwhite
Oven door is in lock mode will not open
Hello friend, thanks for your post!
I understand that you are having some challenges with your Electrolux range. On your control panel if you have a "Clear/Cancel" button you can hold that down for five to ten seconds and it should release the latch. You can also hold down the light switch button on the oven door frame and the cancel button simultaneously for five to ten seconds to see if that would correct the problem. Last, I would perform a reset on your range which can be done by disconnecting power from the range for ten minutes. I hope this information has been beneficial. -Matt
Oct 18, 2014 | Electrolux Kitchen Ranges
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
Screen is frozen
Hold down the power button for more that five seconds to force shutdown. If it goes into sleep or standby (power light flashing slowly) the press power button to power up the press and hold power button again for more than five seconds.Power light should go off then. You can the power up again and it should be OK.
May 29, 2012 | Computers & Internet
My phone goes into sleep mode every ten seconds. How do I turn off the sleep mode?
If by sleep mode you are referring to display shut down than it is simpe solution, you just go to Settings -> Display and under Screen timeout change a setting to whatever time you like ...
Aug 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
My IPhone has frozen and I can't even shut it down. Can you help me with this problem?
you can try the following steps
  1. Press and hold the Sleep/Wake button until the red slider appears. When you see the red slider appears, release the Sleep/Wake button.
  2. then press and hold the Home button for six seconds
if the screen is still unresponsive try to restart the iphone by following these steps
  1. To turn the unit off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn the iphone on, press and hold the Sleep/Wake button until the Apple logo appears.
if restarting does not work, try resetting the iphone
1. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds or until you see the apple logo appears
if your screen becomes responsive, try to reset the settings by going to the settings of y ur iphone then general then reset and reset all. after this, restore the files on your iphone through itunes
Apr 20, 2011 | Apple Cell Phones
My phone wont switch from the apple screen its frozen and wont hold a chrge, ive replaced the battery and still no change when plugged in it shows the apple sign and flicks off every 20 seconds or so and...
Hi, this sounds like it's not as much of a charging problem as it is a software problem.
This sort of situation can happen when the software on your phone becomes corrupted. The phone will try to reboot over and over like what you're describing.
The only way to fix this problem is to do a complete restore from Apple. First, connect your phone via USB to the computer you regularly sync it with and then start iTunes. Next, place your phone in front of you. You'll need to put your phone in safe mode (also called DFU mode) to do a successful restore.
To do this: 1.] Hold down the sleep button for exactly five seconds. 2.] While continuing to hold the sleep button, take another finger and hold down the home button (the one below your screen) for ten seconds. 3.] While continuing to hold the home button, let go of the sleep button and continue holding the home button for another ten seconds.
iTunes should automatically detect that your phone has gone into DFU mode and will then request to do a full restore.
Mar 11, 2011 | Apple iPhone Smartphone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
