My screen says tempering datected 04008 pls reboot so in this stage what should i do so my machine will start
2 Suggested Answers
My iPhone 6s want turn on it just shows the apple symbol then turns off
have your tired a fresh reboot. by holding the home button and power button till your iphone restarts?
Jun 03, 2016 | Apple Cell Phones
I HAVE a reboot notice: TAMPERINg detected 04008. REBOOT
you will need to see if you can change the date in the terminal if you can then it will bypass this error if you can not you will need to replace your machine.
Step 1: Select GREEN ENTER key
Step 2: Select the PURPLE MORE key
Step 3: Select SET UP
Step 4: Type in your password if applicable (1 Alpha Aplha 66831)
Step 5: Select the PURPLE MORE key until the display reads SET DATE/TIME
Step 6: Select SET DATE/TIME
Step 7: Enter the correct date (MM/DD/YYYY)
Step 8: Enter the correct time (military time) (HHMMSS) Select ENTER
Step 9: Select the RED CANCEL key
OR
Step 1: Select F2/F4 at the same time
Step 2: Type in your password if applicable (1 Alpha Aplha 66831)
Step 3: Select the PURPLE MORE key
Step 4: Select CLOCK
Step 5: Select EDIT
Oct 22, 2014 | VeriFone Omni VX-510 Credit Card Machine...
My computer is in one stage telling me the application is missing or corrupt, it stays on that one screen, i need help to reboot it to factory settings
Hello.
Reboot your computer and during the first part of start up repeatedly press the F11 key. This will successfully restore your all settings.
Hope this helps.
Dec 26, 2010 | Compaq Presario CQ60-220US PC Laptop
Picthure has gotten shorter and shorter over the last few months and now only fills 1/3 of the screen
this problum is vartical stage in tv set pls check vartical stage capaciter or pf .
470uf/63v /1000uf/63v 4.7uf/50v /0.47uf/50v cheked or Replace all vartical stage capaciter .this problum is not creat long time in futuer.
Oct 04, 2009 | Televison & Video
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
I have a HP dv2120us computer. The machine starts and runs fin then after about 10 minutes the screen changes to all kind of gobbly-gook and the machine freezes. If I reboot it. it starts fine but then...
pls see this regarding ur notebook i think it might be this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&lc=en&dlc=en&product=3245591
Apr 03, 2009 | E-Machines eMachines T3830 PC Desktop
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Hi when starting up the laptop a screen comes up saying 'configuring updates stage 3of3 - 0% complete Do not turn off your computer. then it seems to restart and the same happens again. ca you...
Use your OS disk to access the Vista repair tools.
Even for those without an OS disc, Vista has repair tools built in.
To access them, boot the computer, but when you see the “Microsoft (C)” with the moving lines, hold the power button until it shuts down. Now windows thinks it didn’t boot properly, and when you turn it back on, you should get the option to run Windows Startup Repair.
Choose this. When it loads, cancel the scan it starts (it won’t find anything anyway), and choose the text on the bottom that says something like “Show advanced repair options.” which should get you to a command prompt option. (Some folks are saying that it asked for the user, and they changed from the Administrator to their user account in order to get access to a few more tools, including a command prompt where you can run fixes).
You can also get to a command prompt via holding down, or repeatedly clicking, F8 as the computer begins its reboot. - select safe with command line.
note that this may take a few runs through the reboot F8 routine as my initial runs still ended up with the forever loop. Which is why the OS disk route - if your machine came with or you later bought such a disk - is preferred. If you are lucky ebough to have a restore point established, that option appears to work on a little less than half the machines I've run into.
Once you have the command prompt the need is to remove a file “pending.xml” that is causing the forever loop Instead of deleting the “pending.xml” files from the c:\windows\winsxs folder I renamed it, so that it can be put back later if needed.
This seemed to do the trick for me. But if it still hangs on "Stage 3 at 0%" with reboot and hang again forever cycle continuing, just do a repeat of the F8, and select safe mode w/networking. Stage 3 may well continue and finish normally (it didn't for me) but in any case after the second "safe" reboot a boot to normal windows was possible for the folks I was helping.
Nov 09, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
