Question about LG Dryers
Where is the fuse on DLGX8001V lg gas dryer - LG Dryers
  • LG Master
  • 2,272 Answers
Does not have one
Posted on Aug 13, 2017
2 Suggested Answers
strech3030us
  • 1554 Answers
SOURCE: how do i take the top off my LG dryer dlgx8001v
Here's a "how-to":
http://www.ehow.com/how_5660964_open-lg-electric-dryer.html
Posted on Apr 06, 2013
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Lg gas dryer wont restart I dried 4 pair tennies in it must of shDLG2302w gas dryer down over load ? wont restart light in dryer comes on though
There is a thermal fuse in the blower housing tht is bad.. what makes it blow the fuse is a clogged dryer vent.. after u replace tht fuse make sure your vent is cleaned out. wht happens is the unit over heats and then blows the fuse..
Nov 25, 2012 | Dryers
Thermalfuse
It's A circuit breaker located on the out side of the burner at the 7 o'clock position. You need to remove the front panel to get to it. Unplug the dryer before doing this.
Dec 08, 2011 | LG DLG0452W Gas Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
How to lite a gas dryer
Modern gas dryers use electric igniters. If the dryer is plugged in and does not ignite the igniter could be cracked or broken or you could have a bad thermal fuse.
Dec 01, 2009 | LG DLG5932W Gas Dryer
Thermal fuse
hi. thanks for the question. the thermal fuse is located in the dryer, on the air duct, small piece with 2 wires to it. replace . also clean venting, and inside the dryer.thanks the appliance doc
Oct 05, 2008 | Dryers
Runs but no heat
I WOULD LIKE TO KNOW WHERE THE RESET BOTTOM ON A (LG-GAS 7.0 DRYER)
Jul 30, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
27 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
