When u have a reboot 04008 in vx670 then what should i do
I HAVE a reboot notice: TAMPERINg detected 04008. REBOOT
you will need to see if you can change the date in the terminal if you can then it will bypass this error if you can not you will need to replace your machine.
Step 1: Select GREEN ENTER key
Step 2: Select the PURPLE MORE key
Step 3: Select SET UP
Step 4: Type in your password if applicable (1 Alpha Aplha 66831)
Step 5: Select the PURPLE MORE key until the display reads SET DATE/TIME
Step 6: Select SET DATE/TIME
Step 7: Enter the correct date (MM/DD/YYYY)
Step 8: Enter the correct time (military time) (HHMMSS) Select ENTER
Step 9: Select the RED CANCEL key
OR
Step 1: Select F2/F4 at the same time
Step 2: Type in your password if applicable (1 Alpha Aplha 66831)
Step 3: Select the PURPLE MORE key
Step 4: Select CLOCK
Step 5: Select EDIT
Oct 22, 2014 | VeriFone Omni VX-510 Credit Card Machine...
Vx670 default certificate
hi dennis .. as far i know the default certificate is like an operating sys. for the terminal , u should send it to any verified centers for maintenance ..
Aug 11, 2014 | VeriFone new vx670 gprs wireless machine...
Why is my Verifone VX670 beeping? Can I fix it?
check to see if there is button stuck. it sounds like it is just in need of a quick clean to make sure the buttons are not sticking
Jul 15, 2014 | VeriFone new vx670 gprs wireless machine...
How to reboot VX670.
Push F2 and F4 at the same time.
Enter the system password z66831. (You get the z by pressing keys 1, alpha, alpha) choose restart. Opionally remove the power cord then press and hold the red cancel key for ten seconds. Wait for the shut down. Then press and hold the green enter button until it turns back on.
What I do is not reccomended. Remove the battery and the power cable. Then replace the battery and power cable.
Jun 09, 2014 | Retail Supplies
Settings and Printer Issues
hi
try to access the sys. mode by pressing F2 + F4 using the password which it is set by your merchant or try the default password (1,alpha-key, alpha-key,668831 ) where u can find the wanted setting..
for the printer , i thinks the right side of the printer is broken or it may be so dusty . in case of printer damage it should be handled to any maintenance center.
thanks ...
Mar 21, 2014 | VeriFone new vx670 gprs wireless machine...
System error verifone
Dear master. I have a lapos VeriFone VX 680. when i open there are one maggage **security alarm** tampering detected [000C10] please reboot -
Feb 10, 2014 | VeriFone new vx670 gprs wireless machine...
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
Verifone vx670 security alarm
Verifone units has multiple sensors built inside for security reason. If you acceidentally dropped or jarred the unit, the sensors will kicked-in and give that error that you have now. And i'm also thinking about your internal system battery is getting low too and needs to be replaced. Then we need to reload the Verifone Tamper Removal Software to clear the Tamper error. Tamper error can be cleared, if you still need help you can call us @ (775) 358-2922 ask for Randy. Hope to hear from you. thank you.
Jun 23, 2012 | VeriFone Vx 670 Payment Terminal
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
