Question about Hoover Vacuums
Hoover widepath suction ok,but the debrie stays up to the top the filter,then clogs&i get the burn smell.filter is new(#50) all the dirt etc wont collect at the bottom of the reciptical
reddevil6
  • 1673 Answers
SOURCE: Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Posted on Jan 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Posted on Mar 06, 2008
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
worldvet
  • 859 Answers
SOURCE: Dirt Devil M086700 Wide Glide upright suction problem
These new fangled Hepa filters get clogged up pretty easy and when there's no place for an outlet of air there is no suction going into the clear basket.
You're right. Best way to clean these things is to bang them upside down outside on some concrete or another hard surface until there is no more dust coming out. You can replace them and eventually it comes to that.
The hose that leads up from the suction bed housing has a tight turn in the bottom area and this can collect something large that then collects smaller and smaller. The hose can be disconnected from the bottom unit and it may take a straightened coat hanger to clear out whatever may or may not be in there.
To be sure you have a tight seal just see that the plastic can is seated firmly at the bottom and the top locks in place. The gasket does its job once there is good airflow and the vacuum will do the rest.
Any questions or need for clarification just comment back to me below and I'll get back to you as soon as I can.
Regards,
Worldvet
Posted on Jun 10, 2008
SOURCE: filter clogs with every use
What should I do when the dirt Devil Vacuum clener doesn't **** up dirt ?
Posted on Sep 18, 2008
My widepath bagless windtunnel Hoover vacuum cleaner has lost its suction.
Could be a clog somewhere or you need new filters. Change the belt if it's over a year old.
Mar 24, 2018 | Hoover Vacuums
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps.
1. Remove the dirty water tank.
2. Clear the filter screen of any dirt or debris.
3. Turn the cleaner on, check your motor suction by the filter screen.
4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides.
5. Lift up on top of nozzle and slide off cleaner.
6. Wipe debris off nozzle and front of cleaner with a damp cloth.
7. Replace dirty water tank.
If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
Jul 21, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
The vacuum is not picking up at all
if it is not picking things up -- then there is a blockage in the suction hose and /or a clogged filter.
clean and clear the unit and all should be working good as new.
c...
Feb 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
After using my attachments I have a hard time getting suction when using upright again - how do I get the suction on my upright? It's a Hoover blue widepath Tempo~ thank you
It may be clogged underneath the vacuum where the roller is. Take the bottom plate off and look into the intake port. There may be some blocking the port.
Nov 09, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Dusty smell
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=618510
Dusty smell
Posted by chekle on May 23, 2008
I buy loads of Hoovers and always same problem. When I Hoover its a dusty smell and it stays around bag not full and check filter the Hoover is ok f couple days then this happens.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sounds to me that if you have a clean bag and filter, it sounds like you have dust in the motor section and it needs to be cleaned and or take a good blower and blow out the dirt or you may have a clog or dirt build up in the suction line and that might be causing the dusty smell. Please feel free to contact your local vacuum cleaner dealer in your area or call the Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 23, 2008 | Hoover F5881-900 Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Hoover Windtunnel
Dec 28, 2007 | Vacuums
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
