Question about Whirlpool Home
I have an aquaglass whirlpool tub mod# aq6791w need control panel, the speed cobrokentrol knob
    Top Expert:
  • Whirlpool Master
  • 43,983 Answers
Fixya does not sell replacement knobs.
Posted on Aug 13, 2017
emissionwiz
  • 79865 Answers
SOURCE: fan control knob has only two speeds,
there is no computer control unit, what u need to replace is the fan speed control resistor module.
Posted on Mar 22, 2009
crouchdash
  • 83 Answers
SOURCE: Plastic knobs (off/on and fan speed) are broken. Need replacement
Only accredited service contractors carry them. You need to contact them for price and availability.
I hope this helps.
Posted on Jul 06, 2009
  • 491 Answers
SOURCE: four inch crack in the bottom of aquaglass tub styren
CONTACT COMPANY THAT FIX CRACKED CAR WINDSCRENS, THEY CAN PUMP A POXY RESIN INTO CRACK .
Posted on Oct 13, 2009
  • 100 Answers
SOURCE: whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
Posted on Feb 14, 2010
  • 14390 Answers
SOURCE: customer wants polycomposite tub wall panels over
advise client panels will most likely shift or not bond correctly when adhesive is applied to wallpaper also will have a mold problem from moisture trapped between panel and wallpaper and depending on thickness of panels the embossed paper may create bumps/waves in panel
Posted on Apr 08, 2010
Aquaglass whirlpool tub
Does you tub have the air system installed? If so you may have the air system advanced function. There are two types of air system advanced functions.
  1. With water level detector: A 30 second Drying cycle Will automatically start 20 minutes after the control has detected there is no more water remaining in the tub.
  2. With out water level detector: A 30 second Drying cycle Will automatically start 20 minutes after the complete stop of the blower.
If you have the first type this may be normal or the water level sensor may be dirty or faulty.
If you have the second type it may be a control board problem.
. Hope this helps.
Jan 12, 2014 | Home
AquaSense by AquaGlass
The control & pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system will include the following items:
· New Pump
· AirStreme Control box and topside control
You will change out everything from the old system with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/0108-205005.aspx
US Parts Center
Nov 24, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Our aquaglass whirlpool tub runs for about 10 minutes then cuts off. It will come back on for just a few minutes then cuts off again.
When a motor is doing this it is overheating. You should replace the motor as soon as you are able to. This could cause more trouble for you soon because the motor is over heating.
US Parts Center
Sep 02, 2013 | Home
Where can i purchase an on/off switch for my aqua glass whirlpool tub
We have all the old Aquaglass switches or the replacement for the ones that are not made anymore. Aquaglass Parts
Contact us at: sales@uspartscenter.com or Toll Free 888-521-6183
Rod
US Parts Center
Jan 15, 2013 | Home
I have an Aqua Glass tub in the master bedroom. Today I filled the tub to clean the tubes out and the pump won't work. It almost sounds like it's lock up? When you plug it in and push the ON/OFF...
We service a ton of Aquaglass products. Need to know what kind of control we are talking about. Is this an electronic button you are pushing or an air button you push down?
US Part Center
Aug 13, 2011 | Home
Customer wants polycomposite tub wall panels over existing embosed wallpaper product is AquaGlass Avondale tub wall set.
Apr 06, 2010 | Home
Whirlpool tub pump only runs in slow speed
Feb 14, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Four inch crack in the bottom of aquaglass tub styren
I would contact Whirlpool directly to even see if it is possible. I tried to repair an acrylic tub one time and it didn't keep because the the constant water on it. If it can be repaired, they will give you the solution and info for a contractor that might be able to do the work if you can't do it yourself.
Mar 17, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
Home Logo
56 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
